Merten 507900 / ZCU201 USB Interface Z-Wave
jakkes
Post by jakkes »
I have the stuff as mentioned above.
In Homeseer the USB Interface is seen correctly on Com7
So now i want to add the merten to HS.
Should it be done with "Manage" and then "import Devices"?
I get this message:
Loading network information from your Z-Wave interface... Done.
Synchronizing network information against HomeSeer devices...
No nodes were found in the Z-Wave interface.
Finished with Z-Wave device synchronization.
jakkes
Post by jakkes »
Is there someone who can tell me how to add Z-wave devices to HomeSeer....
Wim2008
Post by Wim2008 »
First start with upgrading Homeseer to version 2.4.0.1. Gives better support with zwave and devices.
Second you have to import de Merten products on the usb-stick.
- Close homeseer and get out the usb-stick.
- Go to you Merten unit and import it on the usb-stick.
- Put your stick back in your pc and start homeseer again.
- Now import devices.
B.R. Wim [:)] [;)]
Return to “Z-Wave Forum”
