The Aeon Labs door/window sensor.
beatboxer05
Post by beatboxer05 »
Hello everyone,
At the moment I am active with the Z-wave technology. I want to buy the Aeon labs door/window sensor, but I need to know if this module works under homeseerpro. Please leave a message behind if you know the answer for my question.
Kind regards,
Niek
Alexander
Re: The Aeon Labs door/window sensor.
Post by Alexander »
Yep HS is compatible.
Alexander
abl
Post by abl »
Can anyone tell me how to install this device (I didn't get the manual)? I just googled but I only got information how to include this in your z-wave network not how to install this actually...
For someone that has done this many times this might seem obvious, but for a layman as me I'm not sure what to do...
Alexander
Post by Alexander »
What do you mean with install: physical or software-based?
Alexander
abl
Post by abl »
I meant the physical installation.
Alexander
Post by Alexander »
This manual you did see?: http://www.aeon-labs.nl/download/AEO_DWSENS_in_en.pdf
To install, just mount one part on the frame and the other one on the door. Such as : http://www.eemlandtechniek.nl/illu/alarm/PICT0016.JPG
Alexander
structor
Post by structor »
In my test setup I have one running and it was by far the easiest device to mount and configure. It's as simple as screwing the frame on the doorframe and the magnet on the door. Place the device, place the outerhull over magnet done... If you have a specific question, just ask.
Alexander
Post by Alexander »
Structor,
Can you please post some pictures of the inside. I'm curious if it is easy to connect wires to the system instead of using the magnet system.
Alexander
structor
Post by structor »
Alexander wrote:Structor,
Yup I will post some images tomorrow.
mhn
Post by mhn »
According to zwaveworld forum, you have to use the Everspring door sensor for easy modding (Or whatever brand it is sold as.)
Regards
Morten
Alexander
Post by Alexander »
you mean this post? : http://zwaveworld.com/forum/index.php?showtopic=553
Are you a user on that forum? If so, can you post the pictures from that topic to this one?
Alexander
mhn
Post by mhn »
Yes I am a user there.
I reduced the big pictures.
Regards
Morten
Alexander
Post by Alexander »
Okay, so that is the door/window sensor you are refering to. Hopefully Structor can post some inside pictures of the Aeon Labs.
Alexander
mhn
Post by mhn »
In Denmark it is sold as Flex-Control FC-0011.
Regards
Morten
structor
Post by structor »
As promised:
Return to “Z-Wave Forum”
