Pieter,
On the new board the HTML-code of some postings is also visible, for instance I can see the formatting HTML code on some postings of Enver
for instance this post viewtopic.php?f=35&t=3447 contains this reference
[hr noshade size="1"][font size="1"]Enver
http://twitter.com/Chak64%20My%20Domoti" onclick="window.open(this.href);return false; ... dware.html My Domotica Hardware Software[/font id="size1"]
Or is this due to a browser setting (IE-8)
Erik
HTML visible on some psotings
Moderator: TheHogNL
Re: HTML visible on some psotings
yes
those are some old posts
also happening with the {quote} and some other stuff
I'm busy with this but phpbb does not make it easy for me as certian fields are store as UTF8-BIN in the database.
Will be corrected soon
It's just a matter of replacing the < and > with a [ and ].
I wish it was that easy
Ok, that's a pitty.
It's what I did with all my posts in which it showed the html language.
After that all was fine.
What seems to be the problem then with the conversions?
OK
perhaps you had a simple one
the above post does not work that way.
And then there are the nested Quotes which are evnn more complicated
I'm trying to update the post with a script now
But if everyone comes alone his own post and update it manualy it would help a lot
Thanks
Thanks
I understand, sorry to make it sound easy which it obviously isn't.
- Willem4ever
- Global Moderator
Indeed much more complicated check here for some guidance to help change your own posts
