I just installed the HStouch Iphone plugin and made a one button test screen:
320 wide, 480 high. Marked the Ipod/Iphone at project defaults.
The connection also works (both local and remote)
But when my ipod touch connects is says building screens and the screen stays blue and there are no buttons.
Can anybody tell me what I'm doing wrong?
When I open the project on a PC it works fine...
Also the HS log shows that the Ipod is connected.
No screen on Ipod touch
- Jeroen Bartels
- Advanced Member
Last edited by Jeroen Bartels on Mon Jan 11, 2010 2:38 pm, edited 1 time in total.
**Jeroen**
Re: Geen screen on Ipod touch
Iphone heeft wel wat beperkingen in het weergaven van wat complexe info maar een toets moet direct werken.
kijk in de instellingen scherm of het juiste project actief is.
wat je ook kan proberen is applicatie op de iphone verwijderen en opnieuw toevoegen.
Er wordt dan een standaard project toegevoegd wat zal werken nadat instellingen zijn aangepast.
- Jeroen Bartels
- Advanced Member
OK, I re-installed it and also found the iPhone.xml file.
In the end the problem was caused by the fact that I did try to have the iPod get the XML file instead of sending (deploying) it to the iPod.
What I should have done is to open iphone.XML in the designer and DEPLOY it to the iPhone/Ipod touch.
I gues the iPod knew the name but was looking in the wrong map.
Once you deploy it keeps on working fine.
Tonight I will start to make my own iphone screens.![Smile :)](./images/smilies/icon_smile.gif)
**Jeroen**
Re: No screen on Ipod touch
Any one a sugestion for my problem ?
after 4 days trying now and then i am out of options...
hstouch boots up ask local or remote....
connects to hsserver but then fails after recieving devices from hs.
On the moment i expect hst to buildup the screen, hs server disconnects and the ipod touch 3g gets back to its home screen.
reinstalled all plugins and hst on the ipod but no luck here.... even started from scratch with a clean ipod.
Sometimes if i am quick i can deploy from hstdesigner to the ipod, sometimes it fails sometimes it deploys but it never boots up on the ipod.
