** This update is for all users **
Plugwise Source 2.14 Release 20100302
After you install this update, click the update button again to update to firmware (update release) version 2: 2009-09-08
Fixed:
-#799 OTA: When updating multiple networks, the windows close unexpectedly
-#761 Not all retrieved data is processed; graphs show gaps
-#752 Fast schedule verification does not work when schedule contains standby values
-#748 Cannot remove Switch that does not come online
-#709 Week, month en year graphs do not distinguish between usage and production
-#705 Wrong week numbers in Dutch
-#703 USB icon stays in Busy state after sending broadcast groups.
-#695 Peak/offpeak graph not correct in weekends
-#691 After deleting a room, appliances do not show up in list
-#690 ConfWiz: After every run an new tariff is added.
-#622 Switch button list not visible yet just after adding first Switch
-#596 OTA: no updates when network only consists of Stick and Circle+
-#499 OTA: Update of unassigned Stick failes
-#465 Save button not fully visible in Tariff screen
-#444 OTA: Cannot select network in case of multiple networks
- Serveral crashes
Changes:
- Appliances: Power production has a seperate column
- Tariff: Days of week to use peak tariff for are selectable
- Pro: Network names can be changed
- Pro: List of networks added
- Setup: Any installed PDF reader will be detected, not just Acrobat Reader
- OTA: Suppport for Switch
- OTA: Will now work via Stretch Lite Pro
- OTA: Update multiple networks simultaneously
Known issues:
- Manuals need updating
Notes:
- If you're having unexplainable holes in the graphs of one ore more appliances do the following. In the Reports screen, select the appliance, click the refresh button while holding down the Shift key and then wait for a few minutes.
Plugwise Source 2.12 Release 20091224
Fixed:
-#634 Switching schedules not activated / standby killer not working
-#609 Long periods of high CPU usage
-#598 Downloading updates fails if ReadMe.rtf is opened and locked by MS Word
-#471 Savings numbers not correct when period starts on any other day than monday
Changes:
- When Reports or Appliances screen is open, the currently selected appliances are refreshed about every 5 seconds (plus the total time required to query the modules of those appliances).
- Source is activated directly after completing Configuration wizard. The activation mail is no longer required.
New Release Source 2.14 now available!
Re: New Release Source 2.14 now available!
Before the update to V2.14, the Plugwise Webserver updated the total usage per device (only) once per hour, or sometimes once per 2 hours.
Since the update to v2.14, the webserver no longer updates the total usage per device at all!
The actual usage per device is correctly shown and updated by the webserver and by Source (the usage values do change), but the total usage is only shown correctly by the webserver when it is (re-)started, the values do not change anytime thereafter until the webserver is restarted again !-(
In the Source, the total usage is updated like normal, showing higher values than the webserver.
Does anyone eldse notice this too since v2.14, or is it just my setup?
PS: I did not yet update the circles firmware (I believe this is irrelevant to the issue above).
I just checked it and I can confirm this.
After a restart of the Source, the webserver provides the new totals but only after a restart of the Source.
When you let the webserver run, the totals stand still, also after a restart of the browser.
Thanks for doublechecking this, Darwusch.
I just sent a problem report to PlugWise.
Anyone who wants this fixed, please also ask PlugWise to fix it!
I do not only notice this in the web server but also in the appliance (apparaten) view of the Source. I made a screendump last night at 21:30 and right now, the next day at 10:48, all totals are exactly the same while for instance the washing machine has made a few turns.
It is not that bad in my setup. You may want to check the time period selected in the appliance view. If you select a period in history (e.g. yesterday), the total usage value shown in the left bottom area reflects the total usage in the selected period, which obviously does not change anymore once yesterday is gone.Rene wrote:I do not only notice this in the web server but also in the appliance (apparaten) view of the Source. I made a screendump last night at 21:30 and right now, the next day at 10:48, all totals are exactly the same while for instance the washing machine has made a few turns.
The total value that the webserver gives (correction: should give) is the total since the plug started measuring.
status update: plugwise already responded (
![Smile :)](./images/smilies/icon_smile.gif)
![Sad :(](./images/smilies/icon_sad.gif)
In the appliance view (apparatenscherm) you cannot select a time period. It shows the total usage since starting measuring and does not update since version 2.14. In the overview (overzichten) view, the total usage is increasing.
According to Plugwise, in the new beta (2.15) Plugwise Source, this issue (total usage) is solved:
Plugwise Source 2.15 Beta 20100310
Fixed:
-#822 TotalUsage no updated every hour
-#821 Must 'Run as Administrator' to use webserver on Windows Vista and Windows 7
-#816 Reports: graph uses peak/offpeak in weekends
-#817 Reports: long frees after clicking Export on system with large database
-#783 Reports: No hourly graphs unless period is 3 days of longer
Changes:
- Source no longer requires 'Run as Administrator' to enable the webserver.
- PTE: HTML output defaults to chartype=utf-8 (/sys/mimetypes.txt)
- German translation
Known issues:
- German manual missing.
Notes:
Fixed:
Changes:
Known issues:
Notes:
The new beta indeed fixes the problem updating the totals, both in the appliances view of the Source as well as in the web server (and as a result in the Homeseer plugin).
