watchdog/check software
Pop your questions regarding Home automation software here.....
phoenixb
Post by phoenixb »
I'm searching for a watchdog/check software that can restart 1 time a day a software program but when the software is restarted runs a few mouse handlings.
to accept some pop-ups and set 2 function's "on" in a menu.
Have someone something like that?
Grtz,
__________________
Tiz
Re: watchdog/check software
Post by Tiz »
In the past I have worked with AutoIt to automate some tasks in windows http://www.autoitscript.com/autoit3/index.shtml.
You could make a script with it and then let the script run at times by using windows Task scheduler. Hope this can help you.
Mathijs
Fantic
Post by Fantic »
A program from the old Mac times is QuicKeys, this will allow you to automate many different things like mouse clicks and menu's timed events and much much more. The program was made by CE Software and they also made a Windows version, it is still available for XP http://startly.com/products/quickeys/windows/3/.
Regards, Maarten.
phoenixb
Post by phoenixb »
Thanks for the info, i'm going to look the 2 software solutions.
Grtz,
__________________
