I just ordered a new 7390 and plan to switch to voip completely. Those things can keep you busy
Moderator: RdP
Mine will arrive tomorrow, so I have something to play with this weekendjakkes wrote:hopefully my 7390 will arrive tomorrow...
If it uses the same approach as DomotiGa does by activating callmonitor on the box itself it should work, I went from 7270 to 7390 on cable later fiber.sddroog wrote:Mine will arrive tomorrow, so I have something to play with this weekendjakkes wrote:hopefully my 7390 will arrive tomorrow...![]()
Hopefully the plugin will continue to work with a 7390, but I am pretty sure it will.
But I don't understand that the plugin will not get any names from callers anymore from the Internet... Am I really alone with this problem?
The web-if is pretty much the same, only next version(.86 on the german version) will have a revamped web-if.Digit wrote:The Plugin does a bit more than just listen to the callmonitor.
It also logs in to the web-interface to be able to do more things, like retrieving the phonebook and switch WLAN on or off.
This makes the chance of failure when switching to a newer model a bit higher.
Ik heb gisteren even met fiddler zitten kijken wat je precies naar het internet stuurt, maar dat is gewoon goed. Er komt ook een antwoord terug met de juiste informatie. Blijkbaar gaat het mis in de interpretatie van de html page? Wellicht heeft nummerboek de layout aangepast?sddroog wrote:- For some time now (also with the previous version) it doesn't find ANY names anymore, except when they are in the fritzbox phonelist. How can I troubleshoot this? The debug file only shows:
17-8-2010 14:22:58 Searching Internet for: <number>
17-8-2010 14:22:59 No match found...
17-8-2010 14:22:59 Name found = Geen vermelding gevonden
17-8-2010 14:22:59 Numbers To Display = 0
