Night vision, Zoom, Pan, Tilt, Wireless/ Ethernet
Moderator: Esteban
For the kids room i need two new IP cameras.
My current cameras are working okay..but no IP (Wireless 2.4Ghz)
My interest is going out to this one..what do you think?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... EF:GB:1123
How do you control the camera (Pan, Tilt)?
Pan, +/-150?(0 ~ 360), what does the 150 mean precisely?
What frame rate? (PAL=25fps...)
No example image. I would like to see one before i buy.
Camera is not found on seller's home page.
I don't know what i would do...
it's a risk, CMOS sensor 5.0 lux.
Before I buy it would need to see it in action.
there are few other seller's with same camera (from China)
i can't find any info on the net..
Just send a message to the UK seller.
For this camera you need extra USB wifi adapter..
What I'm looking for Night vision and Wifi.
other option is the Y-cam black.
http://www.y-cam.com/
Specs looks much better!
btw for childrens room do you need pan tilt?
Yep and the Y-cam looks good...small, low power usage 3,75watt
price is a bit higher...
http://www.networkwebcams.com/product_i ... cts_id=618
did not found any dutch reseller.
Axis 207W has no NV
Sometimes i need the pan tilt...when someone is missing in bed...lol
Axis 207W has no NV
Right...
You've probably already seen this already:
http://www.networkwebcams.co.uk/blog/20 ... -cam-black
BTW, ActiveX based, so i guess no-go on your Pronto...? [:)]
yeh thats the other problem....
but the pronto works also with image mode..thats what I'm using now.
hope this on also will work with image mode.
Buy one and you'll know[:D]
maybe..or just ask them..
thanks for the tip...about ActiveX...
I need to watch on my new wall display N810 also
6. Viewing Technologies and Compatibility
As with the Y-cam White the camera is ActiveX based meaning that it will work in Microsoft Internet Explorer only (versions 5.5+). It will run on Windows 2000, XP and Vista. The camera does not provide support for MAC or Linux platforms, or non-IE browsers.
The manufacturer has also told us they are working on multi-platform capability for their cameras so as soon as we have more information on that we will test it and report on it here.
Wll this one work on the Pronto?
http://www.allnet.de/product_info_allne ... _id=100138
[img]uploaded/Chak/2008224212654_ALL2281_200px.jpg[/img]
You can even download the firmware sourcecode[8D]
It has capability of taking a snapshot (page 8 of the manual), so my guess would be yes. You take x snapshots per second and it should work
Don't Axis servers work with MJPEG? Can that be used? (Pieter, Erik?)
- Snelvuur
- Forum Moderator
- Contact:
It says http protocol too, so if you can get an image via an url, then it should work.
On e-bay they ask 139 euro
I'm not sure if it will work, I think you need some setup examples from the manual.
Mjpeg for the AXIS needs an ActiveX control in the browser, so I thinks this will be the same with the Allnett camera.
If you can run it from within a browser that can be done in many ways.
Agree with Digit, if you can grab a single JPG image from the camera it will probably work.
