RFXCOM Meter and PWR - doesn't get data from PWR?
Moderator: b_weijenberg
DJF3
Post by DJF3 »
I have installed an RFXCOM Meter and Pwr. Homeseer immediately recognizes the Meter and it can be added. The Pwr doesn't show up in HS2.
When I shutdown HS2 and connect to that COM port using the RFXreceiver program I <i>do</i> see information from the Pwr module coming in..
HS2:
RFX_Meter_Meter \4 1-Livingroom RFXMeter RFXMeter[240]M 0 1 1
Any ideas?
Thanks!
bye
DJ
DJF3
Post by DJF3 »
Not sure if this is related, but I do see the following messages in the HS2 log:
2/19/2008 1:34:04 PM - RFXCOM - (RecRxChar) duplicate packet ignored: 20609F20DF
2/19/2008 1:34:04 PM - RFXCOM - (RecRxChar) packet received: 20609F20DF
BTW. Thanks to the RFXCOM receiver I found an Oregon device in the neighborhood that tell me the temperature and humidity. No clue where they are but I do know the battery is low! ;-)
b_weijenberg
Post by b_weijenberg »
set debug level 1 in the RFXCOM plugin and email me the HS LOG with some trace messages of the RFXPwr
andywee
Post by andywee »
i'm having the same issues as DJF3-2
/8/2009 3:11:56 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 packet: 501A2D20DE802670C7571B
2/8/2009 3:11:56 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 packet: 501A2D20DE802670C7571B
2/8/2009 3:11:56 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 duplicate packet ignored: 501A2D20DE802670C7571B
2/8/2009 3:11:57 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 packet: 501A2D4072402620042F4D
2/8/2009 3:11:57 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 duplicate packet ignored: 501A2D4072402620042F4D
2/8/2009 3:12:00 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 packet: 501A2D101A702880063B36
2/8/2009 3:12:00 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 duplicate packet ignored: 501A2D101A702880063B36
2/8/2009 3:12:15 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 packet: 3000F000000000
2/8/2009 3:12:15 AM ~!~RFXCOM~!~(RecRxChar) receiver #1 duplicate packet ignored: 3000F000000000
andywee
Post by andywee »
just to confirm on RFXMeter, the clamp has to clamp to LIVE only or I can clamp to a cable that has got all Earth, Live and Neutral?
b_weijenberg
The CT must be clamped on the live only.
mo046
Post by mo046 »
Bert,
could you please explain why it would only work on the live wire? The device measures current, and that's the same on the live and neutral wire.
** Maurice **
b_weijenberg
If you clamp a CT on both the forward current has the same value as the backward current. See the forward as positive and the return as negative. The result will be zero and no current is measured.
mo046
Post by mo046 »
Maybe my question was not clear: the CT should be clamped on either the live wire or the neutral (return) wire? It shouldn't matter on which of both because through both wires runs the same current? It's clear to me that the CT shouldn't be clamped on both on the same time!
** Maurice **
b_weijenberg
the CT can be clamped on the live OR the neutral.
