Hi everybody,
I'm using the HCB which works fine here. The only thing I can't use, and I'm probably missing something, is linking the buttons to actions. I can see them in "bediening" and give button 1 etc. a name, but where can I link button 1 to a device or macro ?
I'm sure it's something pretty simple.
the software is the latest 1.6
Thanks for your reply.
Best regarda
Luc
Buttons in portal HCB
Re: Buttons in portal HCB
You can use the portal buttons in a macro ....so create a macro and as an event entry choose bediening and select a button to trigger an action
(only local portalbuttons will work)
example:
Als portaal knop 1 is ingedrukt dan schakel lamp x aan
Henk
example:
Henk
Thanks Henk,
it works!
Best regards
Luc
it works!
Best regards
Luc
