Request
Moderator: b_weijenberg
Bastiaan
Request
Post by Bastiaan »
RFXCOM has a feature that when I click on the status in HS, it redirects almost immediatly to the RFXCOM settings page.
But sometimes you want to stay on the original status page because some other plugin wants to change the settings there...
Is it possible to switch this redirecting on/of and if not could we get a checkbox in the settings to disable it?
Bastiaan
b_weijenberg
Re: Request
Post by b_weijenberg »
Bastiaan,
It is already there:
Release Version 14.0.0.71 Februari 18, 2011
Hidden feature: Startup - Redir=Yes/No added so that the default HS config web pages are redirected yes or no
Add Redir=No to the hspi_RFXCOM.ini just behind [Startup]
No support calls on configuration errors are accepted if this option is set to No!!!!
Bert
Bastiaan
Re: Request
Post by Bastiaan »
Thanks Bert!
Even with setting to NO I know where to find you in the forest :-)
b_weijenberg
Re: Request
I know my answer already:
The HS configuration database and the RFXCOM configuration are out of sync, solution: make a fress Homeseer / RFXCOM installation ;-)
