Hi Digit,
I guess it was indeed truncated. I did copy it from wireshark which is not that easy with long messages. I have now copied the output after I initiate the telnet session:
01 H:IEQ0112015,00bbfa,0102,00000000,45f5c6f1,25,32
02 M:00,01,VgICAQhCYWRrYW1lcgA6FwIPWm9sZGVyIG92ZXJsb29wADXdAgEAOhdJRVEwMTA5NjE4CEJhZGthbWVyAQEANd1JRVEwMTA4ODM2D1pvbGRlciBvdmVybG9vcAIB
03 C:00bbfa,7QC7+gACAf9JRVEwMTEyMDE1AAsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly93d3cubWF4LXBvcnRhbC5lbHYuZGU6ODAvY3ViZQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
04 C:003a17,0gA6FwEBFP9JRVEwMTA5NjE4Kh49CQcYAzAD/wBAVFSRSORU/kEgQSBBIEUgRSBFIEUgRSBFIEBUVJFI5FT+QSBBIEEgRSBFIEUgRSBFIEUgQEhWbETkVRRBIEEgQSBFIEUgRSBFIEUgRSBASFRsRORVFEEgQSBBIEUgRSBFIEUgRSBFIEBIVGxE5FUUQSBBIEEgRSBFIEUgRSBFIEUgQEhUbETkVRRBIEEgQSBFIEUgRSBFIEUgRSBASFRsRORVFEEgQSBBIEUgRSBFIEUgRSBFIA==
05 C:0035dd,0gA13QECFP9JRVEwMTA4ODM2Kh49CQcYAzAM/wBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIRQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhFCEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIRQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhFCEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
06 L:CwA6FwASGgAKgYsACwA13QASGgAKgYsA
02 HEX 56020201084261646B616D6572003A17020F5A6F6C646572206F7665726C6F6F700035DD0201003A1749455130313039363138084261646B616D657201010035DD494551303130383833360F5A6F6C646572206F7665726C6F6F700201
02 ASC V[2][2][1][8]Badkamer[0]:[23][2][15]Zolder overloop[0]5[221][2][1][0]:[23]IEQ0109618[8]Badkamer[1][1][0]5[221]IEQ0108836[15]Zolder overloop[2][1]
03 HEX ED00BBFA000201FF49455130313132303135000B0004400000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B0004400000000000000041FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF687474703A2F2F7777772E6D61782D706F7274616C2E656C762E64653A38302F6375626500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000043455400000A000300000E10434553540003000200001C20
03 ASC [237][0][187][250][0][2][1][255]IEQ0112015[0][11][0][4]@[0][0][0][0][0][0][0][0][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][11][0][4]@[0][0][0][0][0][0][0]A[255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255]http://www.max-portal.elv.de:80/cube[0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0]CET[0][0][10][0][3][0][0][14][16]CEST[0][3][0][2][0][0][28]
04 HEX D2003A17010114FF494551303130393631382A1E3D090718033003FF004054549148E454FE4120412041204520452045204520452045204054549148E454FE4120412041204520452045204520452045204048566C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E45514412041204120452045204520452045204520
04 ASC [210][0]:[23][1][1][20][255]IEQ0109618*[30]=[9][7][24][3]0[3][255][0]@TT[145]H[228]T[254]A A A E E E E E E @TT[145]H[228]T[254]A A A E E E E E E @HVlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E
05 HEX D20035DD010214FF494551303130383833362A1E3D09071803300CFF004448450845204520452045204520452045204520452045204520444845084520452045204520452045204520452045204520452044484508452045204520452045204520452045204520452045204448450845204520452045204520452045204520452045204520444845084520452045204520452045204520452045204520452044484508452045204520452045204520452045204520452045204448450845204520452045204520452045204520452045204520
I added line numbers in front and a hex and ascii conversion from it as well.
about addresses: on line 3, 4 and 5 the output starts with something which I believe is the address of the equipment. I think the 1st one (line 3) is the address of the Max gateway or a general system address, the other 2 (line 4 and 5) are the addresses of the 2 thermostats.
I have again done some investigation with wireshark (and a base64->Hex converter
) this evening (see attached file)
as already mentioned by you, the temperature is in steps of 0,5 degrees C.
I have trouble decoding the date when a particular end date (and time) for a command is set (after which the standard programs takes over again. I'm pretty confident I found the coding for the time and also for the temperature setting.
Temperature settings are always done with the temperature itself, not with "Comfort" or "Eco" I have "Comfort" set to 21 degrees; the command to the Max Gateway is exactly the same for : set to "Comfort" and set to 21 degrees.
the temperatures Eco and Comfort, but also other settings like boost setting and most important the week schedule can be programmed. I guess these setting are on one way or the other in the output after initiation of the session with the Max Gateway.
- max trials3.zip
- file with some decoding results (e.g. address, temperature, time)
- (1009 Bytes) Downloaded 869 times
