Requirements:
1. The flexible pcb MUST be white - it can't be your regular copper/brown pcb color. The LED's will be going on a white ceiling where anything other than white would be an eyesore.
2. I'd love to buy the best, most vibrant RGB LED strips on the market if possible.
3. I live in America, but I haven't found any distributors here for the white strips or the Chromoflex boards making it somewhat difficult to purchase.
4. I'm pretty sure the only way I could pay for any of this stuff is through PayPal - something I've seen accepted nowhere on any of the sites I've checked so far.
Questions:
5. I'd like to run the strips all across my room, which would require about 4 16ft strips, maybe more. The problem is, I don't know how to wire all the strips to the Chromoflex so they can work together - do I solder and run them all to my PC, or do I need 4 seperate Chromoflex adapters to make this work? I don't have a serial port on my computer which if I did my research correctly means I need the USB adapter, which is expensive but not a huge problem I suppose. Daisy-chaining them together also worries me a bit as I'm not sure how one resolves the power situation and don't want to end up overvolting/undervolting the strips.
6. Does anyone know if Winamp can do multiple plugins at once? I also have an amBX setup and I'm afraid using the Chromoflex plugin will force me to turn the amBX off, where I'd like to use both simultaneously.
I'm ready to purchase right now, because I really can't wait to bring them home and make this a reality. Any help I receive is greatly appreciated, and thanks in advance to anyone who puts up with my inane questioning
