I am looking for some new switches and noticed the s10 switches on the following webshop: http://www.elekhomica.nl/product_info.p ... cts_id=656
These are two light dimmer switches (that are not available from x10). The information states that it is compatible with x10 aswell. I was wondering if there is a big difference between x10 and s10 in that case because s10 is also compatible with x10 as well.
thanks
Ronald
X10 / S10
X10 / S10
As far as I know there isn't a big difference. The protocol is almost the same.
But there can be a lot of differences in functions. For example: The S2221 (3-wire dimmer) doesn't send X10 commands when you use the local switch buttons. It will receive them. And you can use the local buttons to control the light. In some situations no problem. In combination with for example Homeseer not so nice.
I prefer the normal X10 devices, although A10 (Xanura) is even better (and more expensive).
Tijmen
Tijmen
X10 / S10
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tijmen</i>
<br />As far as I know there isn't a big difference. The protocol is almost the same.
Tijmen
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thats some information you don't get from the manuals (or i can't find it with the lack of experience in this field). Do you know if there is a 2 device dimmer within the x10 range that does send the x10 command over the powerline?
Tijmen
X10 / S10
I have a Xanura DIX2. You can control 2 devices with this, but none local. So for evey device you need an other module. As far as I know there are no modules which combine local and remote dimming for 2 devices. I'm looking for this module too!
Tijmen
Tijmen
X10 / S10
<br />I have a Xanura DIX2. You can control 2 devices with this, but none local. So for evey device you need an other module. As far as I know there are no modules which combine local and remote dimming for 2 devices. I'm looking for this module too!
Tijmen
So you have to put a module in each light point and a new module on the switch aswell. Thats an expensive hobby
Would be nice if the s10 switch did send the x10 over the powerline. Pitty...
Tijmen
X10 / S10
Welcome to home automation...
