hollie wrote:As stated: xpl-plugwise stalls when it is waiting for a response from the Stick. I assume that the Stick responds to each frame in the same way: one 'ACK' with a frame counter, and one actual response.
I have seen communications like this:
SEND 0023 000D6F0000B1B5B6
RECV 0000 0026 00C1
RECV 0024 0026 000D6F0000B1B5B6 0B0B2462 00048D88 01 85 653907014023 4DCCDB7B 02
SEND 003E 000D6F0000B1B5B6
RECV 0000 0027 00C1
RECV 003F 0027 000D6F0000B1B5B6 0B0E1C 01 01457A
SEND 0040 000D6F0000B1B5B6 00 01
RECV 0000 0028 00C1
RECV 0000 0028 00E5 000D6F0000B1B5B6
SEND 0012 000D6F0000B1B5B6
RECV 0000 0029 00C1
RECV 0013 0029 000D6F0000B1B5B6 0003 001A 00000848 0000 0000 000C
SEND 0023 000D6F0000AF65AA
RECV 0000 002A 00C1
RECV 0024 002A 000D6F0000AF65AA 0B0B2462 00045728 01 85 653907014023 4DCCDB7B 02
SEND 003E 000D6F0000AF65AA
RECV 0000 002B 00C1
RECV 003F 0027 000D6F0000B1B5B6 0B0E1E 01 01457A
RECV 003F 002B 000D6F0000AF65AA 0B0E1E 01 01457A
SEND 0040 000D6F0000AF65AA 00 01
RECV 0000 002C 00C1
RECV 0000 002C 00E5 000D6F0000AF65AA
SEND 0012 000D6F0000AF65AA
RECV 0000 002D 00C1
RECV 0013 002D 000D6F0000AF65AA 0000 0000 00000000 FFFF F080 0008
here an extra response is there for sequence 0027...
or 'mixed' results if the powerbuffer is read and at he same time actual powerusage. Seems like 'source' is running those two processes at the same time, like here:
Here look at sequnce numbers 0052/0053 and 0056/0057
SEND 0048 000D6F0000AF4C47 00048C60
RECV 0000 0052 00C1
SEND 0023 000D6F0000B1B64B
RECV 0049 0052 000D6F0000AF4C47 0B0B1B30 00000000 ... 0B0B1BE4 00000000 00048C60
RECV 0000 0053 00C1
RECV 0024 0053 000D6F0000B1B64B 0B0B2462 00048D98 01 85 653907007324 4DCCDAF3 01
SEND 0048 000D6F0000AF6711 00048C60
RECV 0000 0054 00C1
SEND 0012 000D6F0000B1B64B
RECV 0049 0054 000D6F0000AF6711 0B0B1B30 00011642 ... 0B0B1BE4 000101C4 00048C60
RECV 0000 0055 00C1
RECV 0013 0055 000D6F0000B1B64B 001E 00F1 0000682B 0000 0000 0059
SEND 0023 000D6F0000B1B967
RECV 0000 0056 00C1
SEND 0048 000D6F0000D3595D 00048C60 Buffer:2444
RECV 0024 0056 000D6F0000B1B967 0B0B2462 00048DA0 01 85 653907014023 4DCCDB7B 02
RECV 0000 0057 00C1
RECV 0049 0057 000D6F0000D3595D 0B0B1B30 00001AC2 ... 0B0B1BE4 00001A8B 00048C60
note that in this case source is running on a 'dual/quad core/threat' like CPU (an N550 netbook), so might be running more threats, or running those processes in parallel in an other way.
