I was looking at the duwi z-wave switches but I wanted to use these with the busch jaeger insert.
You can buy these standard with cremewhite "wipper" (sorry don't know the englisch term). Because my house has everything in alpinewhite from busch jaeger, I thought this would be an easy solution.
But as it appears the back of the "wipper" is not the standard from busch-jaeger.
Does anyone knows where to get the "wippers" in alpinewhite?
Or does anyone knows who makes these wippers with the duwi stuff? So might get a dealer where I can get them?
Duwi busch jaeger "wipper"
Re: Duwi busch jaeger "wipper"
For the the BJ line from Duwi there is no other color available.
The standard BJ paddle (gamma) will not fit on the Duwi frame.
The only solution for now
Buy the standard alpine white frame (gamma)
paint the Duwi paddle alpine white.(spuitbus)
I'm affraid when I paint it, you will still see a big colour difference or the glance is different.
Have the fibaro shutter switch alse the possibility to set a opening/closing time of 1 sec?
In this case it will be possible to buy a double standard busch-jaeger switch, build in the springs myself (if that is possible with these switches as well) to make it an impuls button. And then connect it to a fibaro build in switch for shutters.
