Hi!
My problem is that I used AC housecode 7D BF for the rfxcomtx, and for Nexa (AC) units i entered ex K01, K02 etc. How do I enyter this in the new format?
/Otto
Problem with Nexa (AC) after upgrade to 0.1.202
Moderator: RDNZL
Re: Problem with Nexa (AC) after upgrade to 0.1.202
Hi could someone explane how to convert the old standard with AC code 7B BF and with unit code K01, K02 etc?
/Otto
/Otto
Ok I'm stuck, 209 have read my posts but none uses the AC protocol with Domotiga ex KlikAanKlikUit, Nexa? Strange, or maby none have upgraded? I give this forum one more chance...
- RDNZL
- Forum Moderator
- Contact:
I don't know how many nex devices you have, but maybe it's easier/quicker to just reprogram their addresses them with rfxcommander, that way they get new addresses, and you know which ones, and they are the same format as all the other rfxcom interfaces use (xpl for example) , that was the reason I had to change it, otherwise the mess was even bigger later on.
But it's too much work to write a routine to convert from old to new format, just for one time use
Regards, Ron.
