AMST 606 Rfxcom status request open of closed
Moderator: b_weijenberg
vunnie
Post by vunnie »
Hi
I'm fairly new to the whole home automation happen so my apologies if I don't understand you guys at once.
My question is as follows. I want a KaKu AMST-606 window sensor with RFXcom, HomeSeer to perform a event.
At the moment that the KaKu switch is open it gives a dim value of 13%. At the moment that the switch is closed, the value 0.
Now if I create an event where I say "Device value change" equal to 0 then torn on a light. This works fine! But .... as
I say "device value change" equal to 13 nothing happens.
I feel that, for some reason, the values read by home seer do not correspond.
I have already tried to set a "range" but also no result. Also if I change the setting to "any" value change it does work fine so Homeseer sees the change of the switch
I read about AMST-606 but I do not understand scripts etc so I ask some help through this new topic
I would prefer the status in Homeseer to port open or closed. In HS touch I did manage this but in the status of homeseer I only get a value of 0 for closed and 13% for a opened switch.
Someone an Idea
Irritanterik
Re: AMST 606 Rfxcom status request open of closed
Post by Irritanterik »
How did you configured the sensor in HomeSeer? Manual or with the RFXCOM-plugin > Input Devices > Add option?
vunnie
Post by vunnie »
Irritanterik wrote:How did you configured the sensor in HomeSeer? Manual or with the RFXCOM-plugin > Input Devices > Add option?
I added it via the RFXcom configuration page. I Added an input device: " Garagepoort sensor \3 Garage BGG AC Input Device AC[1C105F89]a 0 1 No 200 0 "
Then I went to the status page. There I see the device switching "Closed = off" and "dim 13% = open" If I just could set the value to eighter op or closed it would be ok. In other devices I can change this in the device properties and click on "edit value status" But RFXcom devices do not have this option.
I really have no clue how to change this
Irritanterik
Have you tried the 'Use On/Off status for AC remotes.' option on the RFXCOM-plugin > Input Devices page?
vunnie
Post by vunnie »
Irritanterik wrote:Have you tried the 'Use On/Off status for AC remotes.' option on the RFXCOM-plugin > Input Devices page?
Yes I tried that!
mrtiger
Post by mrtiger »
I have the same problem with my nexa 606 door sensor.
The problem is that it gives you a dim, 54% command when its open and not on.(13% in your case)
I did talk to other people that have the same senor but older verson and they get on and off command out from the device.
I think they have changed the code on the senor, but nexa say they havent change the code for det unit.
I was thinking that it was something wrong with my device, so i did buy a new one but i got the same dim,67% out command.
Did try to make it work with homeseer without any luck:(
mrtiger
Post by mrtiger »
I also read that they have some problem with the senor for tellstick, but tellstick did fix this in the software.
http://developer.telldus.com/ticket/235
Irritanterik
Can you put your homeseer log here?
Maybe it has something to do with the configured device value pairs. ([url]http://www.homeseer.com/support/homesee ... rs.htm[url])
It's worth trying setting a new value-pair with 'on' / 'off' values en use this in your events.
