Creating virtual switch to trigger event
Moderator: RDNZL
Postby Zarco » Sat Feb 09, 2013 9:16 pm
I have been diving the last weekends into domotiga and I like it a lot. I use it to steer the roller shutters in my house,
and I am looking for a way to trigger an event from the website. Knowing that the device list is build dynamical,
I was wondering if it was possible to add a virtual device (switch). This would allow me to trigger an event to open
up the shutters.
What is the best way to achieve this in domotiga?
Kind regards,
Zarco
Re: Creating virtual switch to trigger event
Postby sj3fk3 » Mon Feb 11, 2013 12:21 pm
Yes, you can just add a virtual device. Then add and event, trigger (on change of the virtual device) and action (do "open shutters"). You need a way to translate the domotiga action into a physical action (actually opening the shutters) but I suspect you know (how to do) this.
Kind Regards,
Greg.
sj3fk3
Postby Zarco » Thu Feb 21, 2013 10:28 pm
thanks for the info. I will test it once I have gained access again to my server. Seems that the upgrade to revision 1151 has broken my access,
it cannot load the modules anymore. Once fixed, I give it a try.
Zarco
Return to DomotiGa Forum
