DAIX12 & pulse switch & on / off in one click
Noel
Post by Noel »
I've now added some DAIX12's in combination of a pulse switch (http://www.waakzaamwonen.nl/catalog/pro ... t-nulstand), and the light is now dimming, and un-dimming nicely. (I've not programed the SAIX12 yet)
Now when I want to turn on the light to 100%, I need to press the switch till the light is at 100%. The same thing for turning it off.. I need to press and wait till it's off.
Is it possible to turn the light on / off in one go (one click), and also use the dim function? Something like a short press/click to turn on/off, and long press to dim / un-dim?
Daix will always return the the previous setting when switching on.
To do this with the pulse switch...just push it for short.
for the turn off you have to do the same..
HS 2.2.66 - Plug-ins:
ACT TI103, ActiveBackup, BLEditor, DooNetwork, PowerTrigger, IRtrans, Prontonic, RFXCOM, Rover, Netcam, QuickView, JonControl
Noel
Post by Noel »
It takes about 4 to 5 sec to turn the light completely on / off.
Is this normal?
yep...soft on soft off.
Noel
Post by Noel »
so. 'hard' on 'hard' off is not possible I guess
This option is not available...if it was I will not use it.
Softdim is nice option you get used to it.
