Even if you don't use this, perhaps it will help to give you an insight into scripting with Homeseer.
I have attached a zip file containing a vb script and an ini file.
Please Note: This is not fully tested but it is based on a script used in my system.
I have purposely left out error checking (apart from 1 try catch as an example) to make the code clearer and I have only added the day and week devices so perhaps you could add the month and year devices yourself.
The ini file needs to go into your /homeseer/config folder and the script into your /homeseer/scripts folder.
You will need to edit the first few lines of the script as I have assumed that the main meter device is Q3 and that Today, Yesterday, This Week and Last Week will be devices A1, A2, A3 and A4.
You can run the "UpdateValues" function from a Homeseer event at any time and all relevant devices will be updated.
If you run the "ResetCounters" function from a Homeseer event between 00:00:00 and 00:01:00 the devices will be updated, so yesterday's device becomes today's value and today's device value becomes 0. If it is Monday then the last week's value becomes this weeks etc...
Paul..
Virtual device for usage last day/week/month
Re: Virtual device for usage last day/week/month
- PowerMeter.zip
- (1.2 KiB) Downloaded 390 times
I made another script to control a Z-Wave device by script but the actual device is not responding
The device is changing in HomeSeer but the actuale dimmer is not doing anything. Strange isn`t it?
Sub Main(parm as object)
hs.SetDeviceStatus("Q74",3)
hs.SetDeviceLastChange("Q74",now)
End Sub
The preferred method for controlling a Z-Wave device from a script would be hs.transmit.
hs.Transmit("Q74", "Dim", 50, 0, False, False )
End Sub
In your example you have changed the status of the device within Homeseer but not actually transmitted anything over the Z-Wave network.
Paul..
End Sub
Paul..
This is working indeed, i also needed to add al sleep timer to make it a blinking light
System.Threading.Thread.Sleep(1000)
hs.Transmit("Q74", "Dim", 70, 0, False, False )
End Sub
Instead using System.Threading.Thread.Sleep consider using hs.WaitSecs if you run into problems because this will suspend/block the thread.
{source] http://www.homeseer.com/support/homesee ... meseer.htm
hs.WaitSecs
Purpose
This function waits a number of seconds. This will also allow other operations to take place in HomeSeer by giving up the CPU. It will also keep a script from timing out. The function will not return until the number of seconds have elapsed.
Parameters
Parameter: seconds
Type: integer
Description: This is the number of seconds to wait.
Returns
None.
Example
sub main()
hs.speak "hold on while I wait for 3 seconds"
hs.WaitSecs 3
hs.speak "ok, I'm done"
end sub
hs.WaitSecs
Purpose
Parameters
Parameter: seconds
Type: integer
Returns
None.
Example
sub main()
hs.WaitSecs 3
end sub
