I Know this discussion has been started earlier on forums but here is my problem.
I have an OWL CM119 power meter. I've got It working on the RFXcom interface but I'm still struggling with getting a graph in RFXcharts.
Now I've set up everything as I found on the homeseer forum But.... As soon as the script PH_RFXcom2.vben runs It gives me thefollowing error...
It is in dutch but roughly translated is says that the target of a call has an exception, cannot find the table CentaPower. I also can't get is to work under the utilities graph as it should be there sins it is a CM119 and not a CentaMeter
Anyone an Idea
Kind regards
Vincent
5-4-2013 9:32:32 Info Event Trigger "Scriptrun"
5-4-2013 9:32:32 Info Running script in background: PH_RFXCOM2.vben
5-4-2013 9:32:32 Info PH_RFXCOM2 1.1.0.10 started
5-4-2013 9:32:32 Error Scripting runtime error: System.Reflection.TargetInvocationException: Het doel van een aanroep heeft een uitzondering veroorzaakt. ---> System.Runtime.InteropServices.COMException (0x80040E37): Kan de uitvoertabel CentaPower niet vinden. bij Microsoft.VisualBasic.CompilerServices.LateBinding.InternalL ateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn) bij Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCa ll(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) bij scriptcode2.scriptcode2.Main(String pParms) --- Einde van intern uitzonderingsstackpad --- bij System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bij System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bij System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) bij System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) bij System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) bij Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
5-4-2013 9:33:36 Info RFXCharts configuration change restart
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Shutdown initiated
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Var 1 = 0
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Shutdown Complete
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Startup
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Var1 = 0
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Var2 = 0
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Var3 = \
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Var4 = 1
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 CentaMeter Voltage set to 230
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 CentaMeter Devices 0|0|0|]16|0|0|1|0
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 CentaMeter Options 110
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 General Options 001000
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Wind Gust Values0|0|0|0|0|0
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Temp Values\6|24|-2,7
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 RFXCOM security house code not found!
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 RFXPwr Devices N
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 RFXPwr Last Values
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Options loaded Ok
5-4-2013 9:33:36 Info PH_RFXCharts V1.1.0.10 Startup complete
5-4-2013 9:41:39 Info PH_RFXCharts V1.1.0.10 Day Hi Temp skipped
5-4-2013 9:41:39 Info PH_RFXCharts V1.1.0.10 Day Lo Temp skipped
Owl CM119 Energy monitor Graph
- b_weijenberg
- Forum Moderator
Re: Owl CM119 Energy monitor Graph
is the path correct for the database in the RFX_Charts.ini file? . This ini file is in the HS config directory.
