Control wifi bulb with Zipabox
Moderator: Mversluis
Postby bapthippie » Mon May 06, 2013 1:34 pm
I would like to control my wifi bulbs with a domotic server Zipabox. I have to configure socket request to be converted in Hex before sending.
But it isn't possible with the actual firmware of the box. If you want to support my demand to Zipato team for Hex option on UDP socket :
community.zipato.com/responses/hex-hexa ... hilips-hue
Zipabox is the cheapest domotic box on the market.
And wifi light are the cheapest that i have found in this quality :
http://youtu.be/-Yffjbi8GiY
It must be a very good solution.
bapthippie
Re: Control wifi bulb with Zipabox
Postby labium » Wed May 08, 2013 12:28 am
does easybulb work together with philips hue or are they two different systems ?
labium
Postby bapthippie » Wed May 08, 2013 1:17 am
Hi, it'is different system. Easybulb works with udp hex socket with 6 number, philips use http socket with more possibilities.
bapthippie
Postby jon00 » Wed May 08, 2013 3:15 pm
labium wrote:does easybulb work together with philips hue or are they two different systems ?
I have been testing both the Philips Hue and EasyBulb/Limitless LED bulbs. You may be interested in my comparison matrix which I posted recently on the Homeseer forums. I also took sample light readings which are posted further down the thread.
http://forums.homeseer.com/showthread.php?t=159514
jon00
Postby labium » Fri May 10, 2013 9:37 am
thank you jon00 , very nice and complete comparison matrix.
labium
Postby DJF3 » Mon May 13, 2013 12:36 pm
Has anyone managed to integrate the Easybulbs with Homeseer?
DJF3
Postby jon00 » Mon May 13, 2013 5:51 pm
jon00
Postby DJF3 » Tue May 14, 2013 11:08 pm
I could have known :)
One question on the Easybulbs part: do you have to use the Wifibox? (I mean, if the bulbs do Wifi, why not connect them to your existing wifi network directly?)
Or is that Wifi box needed for the programatic interface (API's etc)
DJ
DJF3
Postby jon00 » Tue May 14, 2013 11:29 pm
You have to use the Wi-Fi box for everything unless you use the hand held remotes. For security, you have to register each bulb with the Wi-Fi box and/or remote control.
jon00
Return to LEDS, DMX & Lights Forum
cron
