Verkocht: RFXio
johnz
Verkocht: RFXio
Post by johnz »
Ik heb een RFXio te koop.
http://www.domoticaforum.eu/viewtopic.php?f=27&t=3512&hilit=rfxio
De RFXio is nooit gebruikt (de ribbon cable is dus ook niet gesoldeerd geweest op een RFXcom).
Vraagprijs 60 euro incl. verzending.
edit: inmiddels verkocht
John
johnz
Prijsverlaging
Post by johnz »
Prijsverlaging: 45 euro incl. verzending
walberg
Re: Te koop: RFXio
Post by walberg »
Wat doet deze precies?
johnz
Re: Te koop: RFXio
Post by johnz »
Deze voegt in- en uitgangen toe aan bepaalde rfxcom's. Hier kan je bedrade sensors op aansluiten, of zaken schakelen.
nawikre
Re: Te koop: RFXio
Post by nawikre »
deze werkt volgens mij alleen op de rfxcom LAN versie toch??
greetz,
Iwan
johnz
Re: Te koop: RFXio
Post by johnz »
Zo te zien inderdaad alleen op LAN en WLAN versies:
b_weijenberg wrote:I have a few assembled and unassembled RFXio Digital I/O sets available. Send me a PM if you want more technical and pricing details.
The RFXio is supported by the beta plug-in version 14.0.0.18 which is available for download on request.
The RFXio Digital I/O interface has up to 8 Input-Output lines. Each line can be configured to be used as an Output using a relay contact or to be used as an Input using the opto-coupler.
The 1 port RFXCOM LAN interface has 2 I/O lines available.
The 2 port RFXCOM LAN and WLAN interfaces have 8 I/O lines available.
The RFXio Digital I/O interface must be connected to a RFXCOM Ethernet interface with a 14 wire ribbon cable.
Important: The 14 wire ribbon cable must be soldered to the RFXCOM Ethernet interface by a person that has soldering skills.
Bert
