This 10-pins RJ45 to usb connector cable is now around 2 meters long. In the RJ45 connector only 4 pins are used, the rest is empty.
I know that you can extend an usb cable to 5 meters, maybe more with a powered USB hub.
I tried it already with an UTP cable, but I saw later that the RJ45 was 10-pins instead of 8
Are there other options or cheap ideas?
I don't want to use an expensive usb over ethernet connector or what so ever.
