No devices in web interface
Moderator: RDNZL
On to the next issue....
I am not sure what caused it, but in the web interface of DomotiGa (on Raspberry Pi) I don't see any devices anymore. I did use to see them, but they are gone.
I did upgrade to the latest version, and changed from gambas2 to gambas 3, although due to some problems acheiving this, I am not sure the upgrade by itself / the gambas upgrade could be the problem. However, trying to reinstall according to the manual on http://www.domotiga.nl didn't bring the devices back.
Anyone recognise this as a "simple" issue (and hopefully with a simply solution)?
Synology DS213+ / Domoticz / RFX Transceiver-e
Re: No devices in web interface
Can you try the following command:
It is should respond with something like:
$ xmlrpc 127.0.0.1:9009 device.list
Result:
Struct of 25 members:
Key: String: 'Porch Light'
Value: String: '1;;light-on.png;;Porch Light;;Frontdoor;;On;;;;;;;;;;;;;;;;2008-12-14 18:00:00;;;;T;;'
Key: String: 'Power Usage'
Value: String: '2;;energy.png;;Power Usage;;MeterCabinet;;4497256;;;;0;;Watt;;;;;;;;;;2008-12-14 21:53:01;;;;;;'
Note: I've been away from this forum awhile because my uptime of my raspberry was very poor.. I changed the device, and hopefully now it will stay on again.
Anyway, I've tried the suggestion, it says:
That's not very helpful is it...
-bash: xmlrpc: command not found
- RDNZL
- Forum Moderator
- Contact:
You have to install it first.
On my Ubuntu distro it's in libxmlrpc-core-c3-dev
$ sudo apt-get install libxmlrpc-core-c3-dev
Regards, Ron.
I have reinstalled everything on the page Web & Mobile Clients - Domotiga but stil... NO devices at all. The webpage http://www.mydomain.com/domotiga is working, the iphone client http://www.mydomain.com/iphone is working. The only issue missing are the devices.
Oh please, it took me another evening without any result. Has anybody an idea? Since I followed everything on the page mentioned, I have the feeling the required xmlrpc should be there. It did mention some xmlrpx with the php5 files, but as I said, no change to the good has been achieved....
Situation:
Raspberry PI B
DomotiGa 1.0.009.
Situation:
Raspberry PI B
DomotiGa 1.0.009.
@mschut:
There can also be something "weird" in the xml response, can you make a tcpdump of the xml-rpc traffic and email it to me?
to make a tcpdump:
sudo tcpdump -i any -s 0 -w /var/tmp/xml.eth port 9009
to make a tcpdump:
Thanks for the reply, I quickly tried, but again:
Sudo: tcpdump: command not found
Something is missing I suppose.....
You can install tcpdump as follows:
$ sudo apt-get install tcpdump
Installed, check.
Performed command, check.
Mailed the file, check.
For me, It doesn't make any sense what's in the file
Found the error, thanks to uAlex73!
"Do not use an "&" in the names of the devices/locations".
Now I know...
Now I know...
