- Advanced Member
- Contact:
Any News regarding toon, is it possible to create a homeseer plugin? I will getting this controller probably in a few weeks.
Regards bart
Regards bart
(ON ESXI )on NUC
(ON ESXI )on NUC
see https://forum.eneco.nl/suggesties-ideea ... toon-4853/
I was looking into grabbing the flash contents (u-boot) but that's on nand which will be difficult to read from (externally).
Afaik there is no API available. But there is a Toon app for Android, so maybe we can get into the protocol with wireshark?bartbakels wrote:Any News regarding toon, is it possible to create a homeseer plugin? I will getting this controller probably in a few weeks.
Regards bart
- Advanced Member
- Contact:
As well for ios i will try to check the packets with wireshark as soon as they install toon. Hopefully soon...
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Hi, since last weekend I too own a toon and would be interested in any progress you guys made on this. Personally I would like to be able to remotely switch the toon from "volg programma" to "Weg".
Jan
Jan
- Member
That's an easy one! Use the Toon App and you can do that. Or use the website www.toonopafstand.nl on any device with a browser and Internet to do the same. (Don't forget to set remote access on the "Toon" to on.
you probably meant https://toonopafstand.eneco.nl/
Sorry I did not mention that I bought the toon on marktplaats and do not have an eneco account. So toonopafstand is not an option for me ![Smile :)](./images/smilies/icon_smile.gif)
- Advanced Member
- Contact:
tomorrow i will recieve my toon. So should i be able to include the toon in my current zwave network? I read some comments on addidng it to a vera, but no devices are created.
also want to know if someone tried some wiresharking by use of the toonapp to the toon so we could reverse engineer this to create a plugin.
regards
bart
regards
bart
(ON ESXI )on NUC
(ON ESXI )on NUC
- Advanced Member
- Contact:
hi,
i tried wireshark, in combination with my iphone app and the toon, however did not found something usefull yet. it was simpler if its possible to monitor directly from the iphone but thats not possible. maybe someone with an android app can try this?
anayone else made spme progress to interface the toon?
regards
bart
regards
bart
(ON ESXI )on NUC
(ON ESXI )on NUC
- Advanced Member
- Contact:
heren,
Er is blijkbaar ook een web app, hier kunnen we wellicht wel iets mee. deze is te bereiken via https://toonopafstand.eneco.nl/
Als men naar de broncode kijkt is dit afhankelijk van een java based applicatie; zie attachment
en roept volgende urls aan; https://toonopafstand.eneco.nl/toonMobi ... chemeState en "/toonMobileBackendWeb/client/auth/setPoint" deze dienen aangeroepen te worden met een parameter. Zonder verschijnt de volgende melding; parameter clientId is required.
Het lijkt op JSON Code send and recieve acties.
Op zich is het javascript goed leesbaar en denk dat we hier zeker mee verder kunnen mocht er interesse zijn.
Kunnen we hier niets mee, ik ben niet zon webbased programmeur en of plugin builder. maar wil graag helpen.
MVG
Bart
MVG
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Interessting stuff! If you add some parameters like these:
https://toonopafstand.eneco.nl/toonMobi ... ecksum=345
That will trigger this message: "Could not validate clientId based on checksum. This incident has been logged!"
oops
Would be cool to figure out what my clientId and checksum is.
oops
![Shocked :shock:](./images/smilies/icon_eek.gif)
- Advanced Member
- Contact:
shit attachment vergeten ...:O
hier is die dan even hernomen naar .js
(ON ESXI )on NUC
(ON ESXI )on NUC
- Advanced Member
- Contact:
BTW the mobile.jsp look intrestring too, i hope somebody can do something with it...
(ON ESXI )on NUC
(ON ESXI )on NUC
- Member
This will give you some pointers.
I included the source of a test page which I will not link directly. Just being careful.
- toon.rar
- (2.5 KiB) Downloaded 796 times
