I'm trying to use the RFXTRX433 via LAN. It's hooked up to a TPLINK-WR703N nano router at ip address 10.0.0.144 running Openwrt. Ser2net is installed and the commands used at startup of the router are;
echo "1001:raw:15:/dev/ttyUSB0:4800,NONE,1STOPBIT,8DATABITS" > /etc/ser2net.conf
ser2net
At my Synology running Domoticz i use the command
socat pty,link=/dev/usb/ttyUSB9,waitslave tcp:10.0.0.144:1001
after starting socat, i can add hardware Rfxtrx433 at port USB9, but there seems no connnection. The log in Domoticz keeps repeating every 30 seconds;
RFXCOM connected to: 10.0.0.144:1001
Error: Sun Jan 12 23:30:36 2014 TCP/IP connection closed!
both log entries appear almost simultanously.
Is it possible what i'm trying to achieve, running RFXTRX433 through LAN?
PS. i have tried adding a RFXCOM- RFXLAN hardware in Domoticz, pointing to the routers address but that doesn't seem to work also
Trying to use RXTRX433 via LAN (Ser2net & Socat)
Moderator: b_weijenberg
- Starting Member
Re: Trying to use RXTRX433 via LAN (Ser2net & Socat)
I have tried this using ser2net but with a Z-Wave stick and ethernet z-wave support on HomeSeer
http://www.domoticaforum.eu/viewtopic.php?f=7&t=9148
I also found this one
http://www.domoticaforum.eu/viewtopic.p ... 285#p67560
- b_weijenberg
- Forum Moderator
RFXLAN is not supported by Domoticz.
Is it possible to connect RFXmngr to the RFXtrx433 IP port?
- Starting Member
Good hint, will try tonight.b_weijenberg wrote:RFXLAN is not supported by Domoticz.
- Starting Member
Not really succesfull yet. Tried installing the drivers kmod-usb-serial & kmod-usb-serial-ftdi on the router and starting ser2net. Most i got was:
Reset receiver/transceiver:0D 00 00 1C 00 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 1D 02 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 1E 02 00 00 00 00 00 00 00 00 00
1CE00000E0FCE0E00E8000001C1CE01C Buffer flushed due to timeout
Is that a snippet of communication starting?
- b_weijenberg
- Forum Moderator
This is a working procedure I have received from a user:
I plugged my USB RFXCOM onto a Linux box (Raspberry PI, sheeva, eeebox, whatever plug…) then typed:
socat tcp-listen:10001,fork,reuseaddr file:/dev/rfxcom,raw &
This means that all streams coming from /dev/rfxcom is redirected to TCP port 10001. Where /dev/rfxcom is linked to /dev/ttyUSB2 (my RFXCOM)
b_weijenberg wrote:This is a working procedure I have received from a user:
Please find detailed description on what to do on client / and 'rfx' server here:
http://domotiga.nl/boards/1/topics/3583
It is completely working solution (TP Link is controlling the RFXCom from a central location in the house) and the post contains information provided by other users of several forums.
Good luck.
I didn`t get a stable setup using socat (process was started multiple times) so for now i installed ser2net
However i`m not there yet because i recieve the following error
Aha just found out that the timeout was set to 15 seconds
apt-get install ser2net
vim /etc/ser2net.conf
#BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
#2000:telnet:600:/dev/ttyS0:9600 8DATABITS NONE 1STOPBIT banner
#2001:telnet:600:/dev/ttyS1:9600 8DATABITS NONE 1STOPBIT banner
#3000:telnet:600:/dev/ttyS0:19200 8DATABITS NONE 1STOPBIT banner
#3001:telnet:600:/dev/ttyS1:19200 8DATABITS NONE 1STOPBIT banner
10001:raw:15:/dev/ttyUSB0:38400,NONE,1STOPBIT,8DATABITS
2016-04-26 15:34:17.286 RFXCOM: Connection reset!
2016-04-26 15:34:17.286 TCP: Reconnecting in 30 seconds...
10001:raw:0:/dev/ttyUSB0:38400,NONE,1STOPBIT,8DATABITS
