But for the people that already have these, i have changed the antenna to a external one to make the reach/distance a little bit better.
I know it is against the rules in some country's but i still wanted to share.
If you want to open up the sensor, beneat the sticker on the bottom or backside of the sensor is a small screw.
Dont forget to unscrew and if all goes ok you will see the following pcb.
as you can see on the picture on the pcb trace i used something sharp like a screw driver or something (watch out you don't hit other components).
The antenna length for this frequency would be 16.4 Cm long, i used this website to calculate it. (http://www.csgnetwork.com/antennaevcalc.html)
upper right corner
There is improvement in the signal, i forgot to check the strength in the devices list but when i was in the garage, about 15 meters away from the RFXcom that has to look trough 3/4 walls i managed to get a reading when looking on te log file by teamviewer.
At some places in the garage there is to much interference i think but when i went to the windows/doors were they would be mounted i got everytime a reading if not opening and closing to fast (rapid every second)
Then i walked up front , thats less difficult actually from where the RFX is located, just 1 wall/windows to go trough but the distance is about 25/30 meters.
