Opentherm with Buderus hvac
Postby Fritzspits533 » Fri Jan 03, 2014 11:00 pm
I have a recent Buderus heating boiler (fuel oil, no gas here), it has an "Open Therm" interface.
This is a local "base controller" BC10, and a room thermostat RC35
The question is what is the probability that the Opentherm gateway works? (basic functions such as monitoring)
I would very much like the heating remote monitoring,
Met vriendelijke Groet Fritz
Reason: translated by google. forum is english!
Fritzspits533
Re: Succes kans met Buderus ketel
Postby marck » Sat Jan 04, 2014 1:19 am
Fritz,
Geen OT, maar monitoren kan mogelijk ook hier mee.
http://www.buderus.de/Online_Anwendunge ... 93338.html
marck
Re: Opentherm with Buderus hvac
Postby Fritzspits533 » Mon Jan 06, 2014 9:36 pm
Dear Marck,
Firstly: thanks for your quick answer.
Yes indeed, that "Easy App" from Buderus looks very interesting, however here in Belgium the local Buderus dealer has no clue how to interface my modern CV to the Internet.
I'm both professional (TV) and Hobby electronicus, so to build something also sounds intersesting.
However I'm not sure if and for howfar my installation supports OT. Before I invest 80 - 100Euro in an OT gateway I want to have some proof it minimal can monitor.
From the net I get the impression Nefit and Buderus have a joint lineup, Nefit is also more poulair in Holland. question is does Nefit support OT ?
Has somebody the Buderus command specification ?, or is that very secret ?
Best regards Fritz (Groetjes dus)
Fritzspits533
Postby roel_v » Thu Feb 13, 2014 12:46 pm
Don't know if this is still relevant for you, but if your heater also has an EMS interface ('old' Buderus and, reportedly, Nefit protocol), and if you aren't afraid to do quite a bit of electronics tinkering, check out http://www.mikrocontroller.net/topic/309075 and all the links in there.
In summary, there are two designs to read this protocol: one based on a difficult to build circuit with USB and CAN bus out, and one easier build around an ATmega32 with Ethernet, which requires more complicated software to read out.
I'm banking on this thing to work for the Nefit - if you're going down this route let me know, we can share experiences.
roel_v
Re: "Opentherm" with Buderus/Nefit hvac
Postby Templar » Fri Dec 18, 2015 9:36 pm
Fritzspits533 wrote:I have a recent Buderus heating boiler (fuel oil, no gas here), it has an "Open Therm" interface.
In case you (and/or others) are still interested in an (Nefit/Buderus) EMS-Gateway perhaps this site is of use: http://emswiki.thefischer.net/.
You have to brush up your German though.
Templar
Return to Hvac, Heating Opentherm Forum
