One thing I like about KAKU (click-on-click-off) is the fact that you can switch locally - without servers or software. So if all fails you can still switch lights.
Now that I'm getting close to having 10 Philips Hue lights in my house I would like to
start using "wall switches" to control them, but not switch them off completely (as the computer would not be able to control them anymore)
-> the current wall-switches already control the Hue lights, but when switched off they are not visible anymore
-> If I remove the current wall-switches and replace them by RF switches that trigger Homeseer to control the Hue lights there will be a significant impact if HS goes down, network is down etc.
So what I was thinking:
1. replace the current wall-switches with ones that are as flat as possible
2. Put a small cover on top of those switches (so I can't easily turn them OFF, taking them out of the RF network
3. Put a wireless switch on top of that to switch the Hue lights
In case of emergency I can always take of the RF switch, the cover and use the normal switch to control these Hue lights.
Q1: What could I use for #1: extremely flat/small, but traditional wall switches?
Q2: What could I use for #2: a cover that sits on top of #1?
Cover for existing light switches?
Moderator: Mversluis
Re: Cover for existing light switches?
in case of an emergency you can always use any smartphone with the hue app to controll the lights?
I've got something like that in the living room. I removed the 'normal' switches and replaced them with very small switches like this one which fit inside the box.
On top of this I have a thin plank of word painted white with Z-wave switches.
It's pretty ugly when the cover is off, but it's only for emergencies (which I haven't had yet
You could also create a thin wooden 'box' to cover the existing switches, they usually only stick out about 8-10 mm.
