radiator valve
Moderator: b_weijenberg
- b_weijenberg
- Forum Moderator
radiator valve
The smartwares radiator valve can be controlled by the RFXtrx433E (not by the RFXtrx433) This function is implemented in the latest firrmware version 233.
http://www.homewizard.nl/smartwares-dra ... kraan.html
- Member
Re: radiator valve
Very nice addition !
Thanks for the info
IF using this, are you able to set the temp from HS touch / homeseer ?
Thanks for the info
- b_weijenberg
- Forum Moderator
Re: radiator valve
This function will be implemented soon in the HS3 plugin.
Functions supported by the RFXtrx433E are:
- Set Day temperature
- Set Night temperature
- Set temperature (5 - 28 degrees)
- Member
Re: radiator valve
OK sounds great.
Thanks
Thanks
Re: radiator valve
Does the valve also provide information about its current setting?
groeten,
- b_weijenberg
- Forum Moderator
Re: radiator valve
The valve is a receive only device.
The current setting is visible on the module.
Re: radiator valve
I guess that it is not supported on my old LAN 2 COM 87005 transmitter?
Re: radiator valve
rightstefxx wrote:I guess that it is not supported on my old LAN 2 COM 87005 transmitter?
