ELV MAX! protocol description
Moderator: jrkalf
mike7
Re: ELV MAX! protocol description
Post by mike7 »
Error323 wrote: For my attempt in home automation I want to bypass the cube completely and control the valves directly via a 868 MHz transceiver. Does anybody here know the internal protocol between cube and valve components? I can't seem to find it anywhere, is it FHT based or completely different?
you can start here domoticaforum.eu/viewtopic.php?f=66& ... mp;start=0
Error323
Post by Error323 »
Excellent! Thank you!
Massi
Post by Massi »
i really can't see the advantage of bypassing the cube (except the €30 not spent, obviously :D).. could you please explain me?
mactoolz
Post by mactoolz »
this is my first post and came across this very interesting topic.
Has anyone tried the protocol on Ethernet socket base with a wago controller 750-880 implemented.
MacToolz
philjung77
Post by philjung77 »
Regarding wall thermostat (device type = 3), the L message contains 12 bytes. Length is 12 (of course :-) ) and last byte represents the real temperature x 10.
0xaf => 175 => 17,5 degrees
Philippe
pbrand
Post by pbrand »
philjung77 wrote:Hello,
Philippe
Don't know if you have a new type wall thermostat Philippe, but my wall thermostat L message is 7 bytes long whereas the actual temperature is represented by the MSB bit of the third byte together with the seventh byte ( x 10).
Peter
Massi
Post by Massi »
Philippe
Peter
12th byte is actual temp*10, so theres a limit: 25,5 degrees. if it's higher, the count starts from 0 again and the first bit of byte 8 (set temp) is set to one
This is the standard wall thermostat.
I don't believe your response can be simply 7 bytes, as always it will be 6 bytes for ecoswitch, 11 for radiator thermostat and 12 for wall thermostat.
Maybe you are not counting starting bytes :)
1) data lenght
2,3,4) rf address
5) unknown
So then there are 7 bytes :)
pbrand
Post by pbrand »
Oh silly me. You are quite right, Massi. I only looked at the specific device bytes and forgot about the generic part :)
Massi
Post by Massi »
pbrand wrote:Oh silly me. You are quite right, Massi. I only looked at the specific device bytes and forgot about the generic part :)
No, you'll not get excused.
For that, you need to add to you blog the protocol description of the s: command :)
mactoolz
Post by mactoolz »
it may be that in the new firmware 1.4.1, the commands have changed in their byte protocol?
Thanks
MacToolz
Massi
Post by Massi »
mactoolz wrote:Hi,
Thanks
MacToolz
my "simple" commands (manual temp set) still work. What commands are you referring to?
mactoolz
Post by mactoolz »
i want to use all the commands. At least M / H / C / L and also the sending of data.
e.g. the byte arrangement of the M command I am missing some information. Rather, I do not know what type specific bytes of information again.
e.g. I have not in my receiving data, the RF address.
Look Please purely in the excel. Since I have the Empfangsdasten divided times.
You may find, for example, the RF address.
Thanks
MacToolz
M-Command XLS.xlsx
M-Command list recorded from wireshark
(18.77 KiB) Downloaded 1261 times
pbrand
Post by pbrand »
I am running 1.4.1 firmware here and have seen no changes in the M / H / C / L messages.
Massi
Post by Massi »
pbrand wrote:I am running 1.4.1 firmware here and have seen no changes in the M / H / C / L messages.
Full quote.
No changes in last firmware
mactoolz
Post by mactoolz »
have you looked at the excel. This is an excerpt from the M command. I see no RF address here. The first topic is described which can be seen in the M-command for a device address.
I do not see them unfortunately. Can you tell me the individual bytes?
Result JEQ0416392	 --> 21('21')	 3('3')	 1('1')	 210('Ò')	 240('ð')	 74('J')	 69('E')	 81('Q')	 48('0')	 49('1')	 54('6')	 51('3')	 57('9')	 50('2')
Result AZ_WandThermo -->	 48('0')	 13('CR')	 65('A')	 90('Z')	 95('_')	 87('W')	 97('a')	 110('n')	 100('d')	 84('T')	 104('h')	 101('e')	 114('r')	 109('m')	 111('o')
Thanks
MacToolz
Return to “Homematic, FS20, FHT, ESA and ELV”
