I run OpenTherm Monitor on my raspberry pi, and then a.o. parse opentherm.dat logs to get internal unit temperatures.
I noticed that after upgrade to 4.2 version, the opentherm.dat log format has changed, and does not include all interesting values.
example 4.2 log:
1;1;0;1;0;0;;20.15;22.16;29.00;75.45;53.87;45.00;60.00;90.00;20150122;12:21:30
example 4.0 log:
1;0;1;1;0;0;;20.22;22.15;3.00;44.96;40.40;45.00;60.00;90.00;58.00;0;0;0;0;100.00;255;0;0;0;0;0;1;0;0;20150122;12:31:30
Is this possible to revert to the previous format, or I am supposed to use 4.0?
BTW. I haven't been able to get the "Graph" data in web interface on my raspberry pi.
Thanks.
OT Monitor 4.2 opentherm.dat log format changed?
Re: OT Monitor 4.2 opentherm.dat log format changed?
Then add whatever values you find interesting.slawekj wrote:I noticed that after upgrade to 4.2 version, the opentherm.dat log format has changed, and does not include all interesting values.
See also this topic.
Thanks!
I haven't noticed the new options, because I use OT Monitor from command-line. And haven't found the thread you mentioned before (despite I tried to search the forum).
I guess I will have to put appropriate entries in .otmonitor-4rc?
And how about the Graph function in web interface? Any clues of what would be the problem?
I have tried various browsers with no luck - IMHO the file returned by server (graph.svg) does not include any data except the grid. I have attached it.
- graph.zip
- (2.85 KiB) Downloaded 453 times
Yeah, that graph is empty. You're sure it was made with otmonitor 4.2? I just tested it again and otmonitor 4.2 on a Raspberry Pi in daemon mode produces a correct graph for me.
The previously attached one was made with OT Monitor 4.0 (haven't managed to reconfigure logs yet), but the same problem is with 4.2.
After further investigation, I just noticed that the problem is only when I run the otmonitor from script:
#!/bin/bash
/home/pi/opentherm/otmonitor-ahf -w 8081 --daemon -d opentherm.dat -a /dev/ttyOT &
the exact same command executed directly from console - the graph is properly displayed.
Do I make a mistake in my script, or is there any workaround?
Thanks.
#!/bin/bash
Thanks.
Are you sure it really is the exact same command? There is no reason the program would behave differently when started from a script. Are you possibly running a different binary from the command line and the script still uses an old one? The graph not being filled is a known problem of pre-4.2 versions of otmonitor, so you really need 4.2 if you want this functionality.
What is the size of /home/pi/opentherm/otmonitor-ahf? For 4.2 it should be 4483929.
You can also create a file called /home/pi/opentherm/html/version.html.tmpl that contains:
Then when you access http://raspberrypi:8081/version.html with your browser it will tell you the otmonitor version.
Version: $::version
I'm sorry, you are absolutely right! My mistake - in my scripts I use links to binaries (ln), and I have used wrong link to otmonitor-ahf 4.0
The graph works, and I have loaded the extended log configuration to 4.2 with -f option and proper datalog {} entries.
Thank you for your help, and sorry again for my mistake.
No worries. Thanks for reporting back that the issue is solved and not leaving me to wonder what happened.
