Hi All
In the latest beta version of plugwise software there is build in webserver.
With this update you will have full control and monitoring over your plugs.
My next step is to control the plugs via Homeseer.[:D]
[img]uploaded/Chak/2008627174552_plugwise.gif[/img]
Plugwise Web Interface
Webservice?
I hope you mean a web-interface (aka webserver) [:)], something like Plugwise having a built-in webserver in their software (the "Source" it is called, right?) to retrieve information from it or to post commands to it.
That would make Plugwise much more interesting!
This would make the Plugwise an interface to your powerline as a HA7Net is to your 1-Wire bus!
To bad they apparently don't need additional beta testers...[:(][:D]
@Digit
you are right I mean webserver.
Interface is very basic but you can build your own.
most important part is the communication speed en security.
That actually would make the plugwise solution interesting! If it's web-enabled it could be relatively easy to integrate it into homeseer.. Not being a real programmer I have to rely on HS ![Wink ;-)](./images/smilies/icon_wink.gif)
