I currently have an ON/OFF thermostat that controls a Logamax Buderus GB112. This is working fine for the last 10 years.
I also have an opentherm gateway. I don't have an opentherm thermostat.
I also have a Wago PLC.
I want to use the Wago PLC together with a server running Linux to control the temperature of my house.
I can connect the opentherm gateway with a serial cable to a linux server.
I have some options with this setup:
- put the opentherm gateway between the ON/OFF thermostat and the Logomax: not possible to control the room temperature
- replace the ON/OFF thermostat with a relay connected to the Wago PLC (and of course a temperature sensor): possible to control the room temperature, but some logic in Wago is needed for a stable room temperature
- same as above, but with the opentherm gateway between the Wago PLC and the Logomax: extra benefit: monitoring and controlling the Logomax
- same as above, but replace the ON/OFF thermostat with a (new) opentherm thermostat: will an opentherm thermostat give a big difference compared to an ON/OFF thermostat regarding gas usage?
Stef
ON/OFF thermostaat, OT gateway and/or opentherm thermostat
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
