visonic smoke alarm
Moderator: b_weijenberg
visonic smoke alarm
Hi, i can't ad a mct425 in my rfxplugin.
It's working fine in my alarm system Visonic power max.
I run the newest plugin rfxhomeseer
gtrtzz Ruud
gtrtzz Ruud
- b_weijenberg
- Forum Moderator
visonic smoke alarm
Use RFreceiver to check if the smoke detector is recognized.
Send a copy of the RFreceiver screen with the smoke detector packet to support rfxcom.
- b_weijenberg
- Forum Moderator
visonic smoke alarm
The Visonic smoke detector is displayed as a DWS[xxxx]S sensor.
BTW, the same is true for an X10 SD90 smoke detector.
visonic smoke alarm
Bert
Thanks for the quick respons!!
Is this something that in een new release wil be fixed?
greetz Ruud
greetz Ruud
- b_weijenberg
- Forum Moderator
visonic smoke alarm
I will add the MCT425 to the Device Type: DS10/90/SD90/MCT302/MCT425 Security Sensor
visonic smoke alarm
Hi Bert it's working fine over here.
Test are oke!!
thanks again
grtz Ruud
Test are oke!!
thanks again
grtz Ruud
visonic smoke alarm
Bert,
I have de same problem with my Marmitek MS13E.
greetz Ruud
greetz Ruud
- b_weijenberg
- Forum Moderator
visonic smoke alarm
The MS13 is an X10 sensor using lighting commands (not security)
You have to enable the house code used by the MS13 on the RFXCOM - X10 config tab.
Create an X10 device on the Status page for this sensor.
visonic smoke alarm
Bert,
I know that it is a X10 device but the MS13e shows a ID in de security tab and a problem with communications is the alarmdisplay.
gr Ruud
gr Ruud
- b_weijenberg
- Forum Moderator
visonic smoke alarm
Impossible! (Or must be a bug in the plug-in)
The MS13 will never create a security ID. Check this please with RFreceiver.
If you clear the heard sensors in the plugin and activate the MS13 I'm sure there will be no security device.
It is possible that will be a security sensor visible after a certain time. This could be a real sensor or a noise signal.
visonic smoke alarm
I wil retry it again.
And let you know the results.
Ruud
Ruud
visonic smoke alarm
Bert,
I have removed de de wrong (ms13) sensor from security.
And now i don't see the ms13 again!
Problem solved
ruud
Problem solved
ruud
