Custom HS3 page for controlling lights with JSON
Moderator: Ruud
Darwusch
Post by Darwusch »
I want to make a custom webpage in HS3 for controlling lights.
It seems JSON is the easiest method.
In the settings I enabled JSON control.
The url I was testing is:
http://192.168.1.96:8082/JSON?request=controldevicebyvalue&ref=76&value=50
(HS3 runs at port 8082)
The lamp I tried had ref id 76 and I expected the lamp to switch on to 50%.
But it did not work.
All I get is the question if I want to download the file JSON.json (559 bytes).
What am I missing here?
Phaeton
Re: Custom HS3 page for controlling lights with JSON
Post by Phaeton »
I open the page/link in a hidden div. Works great.
Verstuurd vanaf mijn M6752 met Tapatalk
groeten,
Darwusch
Post by Darwusch »
It did not work when I set it in an aspx page like this:
hs.GetURL("http://192.168.1.96","/JSON?request=controldevicebyvalue&ref=76&value=50",true,8082)
Somehow this does not come trough.
The line after it however (which I put in as a test line) does work:
hs.WriteLog("Test", "Button 1 from aspx")
Now I solved it with another command:
hs.CAPIControlHandler(hs.CAPIGetSingleControl(76, false ,"50", false, true))
And this works :D
Phaeton
Post by Phaeton »
Thats good to hear. Im curious what you interface looks like. If you want to, could you share screens? Could be a nice inspiration source
groeten,
Darwusch
Post by Darwusch »
Ofcourse, but I don't have a nice screen yet.
I'm testing the functionallity first.
I use the code from the standard file "test.aspx" in the html directory.
Here is the code:
<%@ Page Language="VB" %>
<script runat="server">
    ' Insert page code here
    Dim hs As Scheduler.hsapplication
    Dim plugin As HomeSeerAPI.PluginAccess
    Sub Page_Load(Sender As Object, E As EventArgs)
        ' for use with the HS web server
        hs = Context.Items("Content")
        ' get a reference to the Z-Wave plugin
        plugin = New HomeSeerAPI.PluginAccess(hs, "Z-Wave", "")
        If plugin.Connected Then
            Label2.Text = "Connected to Z-Wave plugin, name=" & plugin.Name
        End If
        Label1.text = "HomeSeer Ver: " & hs.version
		Dim EN As Scheduler.Classes.clsDeviceEnumeration
		Dim dv As Scheduler.Classes.DeviceClass
        EN = hs.GetDeviceEnumerator
		Do
            dv = EN.GetNext
            If dv Is Nothing Then Continue Do
        Loop Until EN.Finished
    end sub
    Sub ButSpeak_Click(sender As Object, e As EventArgs)
        hs.speak(txtspeak.text,false,"")
		Do
            dv = EN.GetNext
		'	hs.WriteLog("SAMPLE", "Found device from aspx: " & dv.Name(Nothing))
        '    If dv.Interface(Nothing) IsNot Nothing Then
         '       If dv.Interface(Nothing).Trim = "Sample Plugin" Then
        '        End If
        '    End If
    End Sub
    Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs)
        'hs.ExecX10("L1", "on")
        'hs.GetURL("http://192.168.1.96","/JSON?request=controldevicebyvalue&ref=76&value=50",true,8082)
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(76, true ,"off", false, true))
    End Sub
    Protected Sub Button2_Click(ByVal sender As Object, ByVal e As System.EventArgs)
        'hs.ExecX10("L1", "off")
        'hs.GetURL("http://192.168.1.96:8082/JSON?request=controldevicebyvalue&ref=76&value=50","",true,8082)
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(76, false ,"on", false, true))
        hs.WriteLog("Test", "Button 2 from aspx")
    End Sub
    Protected Sub Button3_Click(ByVal sender As Object, ByVal e As System.EventArgs)
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(76, false ,"99", false, true))
        hs.WriteLog("Test", "Button 3 from aspx")
    End Sub
    Protected Sub Button4_Click(ByVal sender As Object, ByVal e As System.EventArgs)
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(76, false ,"7", false, true))
        hs.WriteLog("Test", "Button 4 from aspx")
    End Sub
	Private Function GetHeadContent() As String
        Try
            Return hs.GetPageHeader("", "Test Page", "", "", False, False, True, False, False)
        Catch ex As Exception
        End Try
        Return ""
    End Function
	Private Function GetBodyContent() As String
        Try
            Return hs.GetPageHeader("", "Test Page", "", "", False, True, False, True, False)
        End Try
        Return ""
    End Function
</script>
<html>
<head runat="server">
<!-- <%response.write(GetHeadContent())%> -->
</head>
<body>
<!-- <% response.write(GetBodyContent()) %> -->
    <form runat="server">
        <p>
            <asp:Label id="Label1" runat="server" width="210px">Label X</asp:Label>
        </p>
        <p>
            <asp:Label id="Label2" runat="server" width="400px">Label plugin</asp:Label>
        </p>
        <p>
        </p>
        <p>
            <asp:Button id="ButSpeak" onclick="ButSpeak_Click" runat="server" Text="Speak"></asp:Button>
            <asp:TextBox id="TxtSpeak" runat="server"></asp:TextBox>
        </p>
        <br><br><br>
        <p>
            <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Light off" Width="300" Height="50" font-size="32px" />
        </p>
        <br><br>
        <p>
            <asp:Button ID="Button2" runat="server" OnClick="Button2_Click" Text="Light last dim state" Width="300" Height="50" font-size="32px" />
        </p>
        <br><br>
        <p>
            <asp:Button ID="Button3" runat="server" OnClick="Button3_Click" Text="Light 99%" Width="300" Height="50" font-size="32px" />
        </p>
        <br><br>
        <p>
            <asp:Button ID="Button4" runat="server" OnClick="Button4_Click" Text="Light 7%" Width="300" Height="50" font-size="32px" />&nbsp;</p>
        <!-- Insert content here -->
    </form>
</body>
</html>
Darwusch
Post by Darwusch »
I still have a strange issue.
When I choose the "on" state, it Always turns on to the last dim state.
I can not set it to go on at 100%, that does nothing.
The only option I see is set it to 99% to come close to it.
Is there some option (in the booleans maybe) to use the "on" state for the 100% level?
raymonvdm
Post by raymonvdm »
I`m using JSON for my NFC tag scanner (AutomateIT APP on Android) and i just call the url with a browser to fire the event
http://username:password@192.168.1.240:8080/JSON?user=username&pass=password&request=runevent&group=Leven&name=Ik_Ga_Douchen_JSON
