HS3 MQTT Plugin
Moderator: Willem4ever
Re: HS3 MQTT Plugin
Hi Geert-Jan,
Thanks, I have updated the mosquitto broker to 1.4.3 and that is up and working with the plug in on the RPi2.
Just need to work on getting it to send out information!
Thanks
Dad
Thanks
Dad
Re: HS3 MQTT Plugin
I`m also running the MQTT Plugin on HS3 (Windows) and it is picking up the data my raspberry pi is publishing using crontab (temperature every minute) But just found out my SD card died so i cannot give the example of the crontab
But i now would like to know how to use the possibilities MQTT is giving us. I would like to have graphs of several temp sensors. I have done this in the past with some help using mysql. But is this also possible using MQTT ?
The cron entry
The script which was created for me
The output (which is picked up by Cacti)
How do i change this to MQTT because there is an MQTT (free) plugin and not a insert to MySQL (free) plugin for HS3
The cron entry
#* * * * * php /home/domotiga/php_get_status_homeseerDB2V2.php T 3 > /etc/snmp/woonkamert.txt
#* * * * * php /home/domotiga/php_get_status_homeseerDB2V2.php T 6 > /etc/snmp/woonkamerv.txt
<?php
$link = mysql_connect("192.168.110.188", "homeseer", "homeseer");
mysql_select_db("HomeSeerDB2", $link);
array_shift($argv);
$vid = 'value';
$result = mysql_query("SELECT value FROM tbldevices where hc='$argv[0]' and dc='$argv[1]' order by id desc limit 1");
while($row = mysql_fetch_array($result)){extract($row);echo $$vid;}
mysql_close($link);
cat /etc/snmp/kantoort.txt
212
Re: HS3 MQTT Plugin
the MQTT plugin writes the MQTT data in a Homeseer device, the device values are available in events and scripts.
I use 'location2' as device type; Electra, Water, Gas.
The script below is called from a Homeseer event every hour, and writes the actual device values for each device where the type is 'Electra', 'Gas' or 'Water' to a MySQL database. The types can easily be extended, with Temperature, Humidity, etc.
Adapt the fields between'<>' in conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>" to your configuration.
Geert-Jan
Imports MySql.Data.MySqlClient
Sub main(Optional ByVal pParms As String = "")
Dim en
Dim dv
en = hs.GetDeviceEnumerator
if IsReference(en) Then
do while not en.Finished
dv = en.GetNext
if not dv is nothing then
select case dv.location2(hs)
case "Electra"
writeDB("electra", dv, 1000)
case "Gas"
writeDB("gas", dv, 1000)
case "Water"
writeDB("water", dv, 1)
end select
end if
loop
end if
End Sub
Sub writeDB(ByVal dbTable as String, ByVal dvRef as Object, devFactor as Integer)
Dim conn As MySqlConnection
Dim myCommand As New MySqlCommand
Dim timestamp As String
Dim devValue As Integer
timestamp = Datepart("yyyy",Now()) & "-" & Right("0" & DatePart("m",Now()),2) & "-" & Right("0" & DatePart("d",Now()),2) & " " & Right("0" & DatePart("h",Now()),2) & ":" & "00:00"
if NOT dbTable = Nothing
conn = New MySqlConnection()
devValue = Convert.Toint64(dvRef.devValue(hs) * devFactor)
Try
conn.Open()
myCommand.CommandText = "INSERT INTO " _
& dbTable _
& " (deviceName, timestamp, deviceValue, deviceType, deviceId)" _
& " VALUES ('" _
& dvRef.Name(hs) & "','" _
& timestamp & "','" _
& devValue & "','" _
& dvRef.location2(hs) & "','" _
& dvRef.Code(hs) & "')"
myCommand.Connection = conn
myCommand.ExecuteNonQuery()
conn.Close()
Catch myerror As MySqlException
hs.writelog ("datalog", "Error Connecting to Database: " & myerror.Message)
End Try
end If
End Sub
Sub updateCounter(Optional ByVal pParms As String = "")
dim electraTotal as double
dim dev1 as integer
dim dev2 as integer
dim dev3 as integer
Dim arrParm() As String
' Extract parameters
arrParm = pParms .ToString.Split(";")
dev1= arrParm(0)
dev2= arrParm(1)
dev3= arrParm(2)
electraTotal = hs.devicevalueex(dev1) + hs.devicevalueex(dev2)
hs.setdevicevaluebyref(dev3, electraTotal, true)
hs.setdevicestring(dev3, electraTotal & " KWh", true)
end sub
Geert-Jan
Re: HS3 MQTT Plugin
I would really like it if the plugin can also publish messages.
My usecase is that I would like to create some Mysensors based stuff and control them via MQTT. There is a plugin for mysensors, but it's limited in functionality and supported sensors/actors. If your plugin can send MQTT messages (based on created devices in Homeseer) it doesn't matter what actor is on the other side.
Re: HS3 MQTT Plugin
This is already possible on the /MQTTPublish page u can select devices of which the status should be published
Re: HS3 MQTT Plugin
Hi Jeffrey, were you able to make this work? I'm looking to do the same. Did you run into any issues?
Thanks
Al
Thanks
Al
Re: HS3 MQTT Plugin
You should really post this on the HomeSeer forum. There are people looking for it!
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Re: HS3 MQTT Plugin
Hi Al,
Did not got around to test this unfortunatelly.
Re: HS3 MQTT Plugin
The plugin is publishing values without issue
Re: HS3 MQTT Plugin
Hallo Geert-Jan,
Thanks for making the plugin available. I've installed it and it looks to be working well although I still need to test with a MQTT broker. I have a feature request already though
Would it be possible to provide sorting on the MQTTPublish page and perhaps a way to not load all devices at the same time? I have over 1500 HS3 devices, so this page loads very slowly and sometimes times out. When it does load, the devices are not grouped, so hard to find items.
Thanks again!
Al
Thanks again!
Al
Re: HS3 MQTT Plugin
Thanks for letting me know.Jeffrey wrote:Hi Al,
Cheers
Al
Re: HS3 MQTT Plugin
@Sparkman: thanks for the feature request. Sorting the list should not be a big problem. Reducing the devices to load, e.g. with a filter, will take some more time.
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
Thanks Geert-Jan! Just a thought for a filter, a manually created "whitelist" where I could enter the reference IDs of the devices I want to publish would be ok for my needs. Thanks for considering it.
Cheers
Al
Sent from my iPhone using Tapatalk
Cheers
Al
- Starting Member
Re: HS3 MQTT Plugin
I am trying to use Geert-Jan's MQTT plugin and a Raspberry Pi. As per the installation instructions I have:
1. copied the files HSPI_MQTT.exe and Mqttlib.dll to the Homeseer top level folder (/usr/local/Homeseer on the Pi)
2.copied (for now, the original) file hspi_mqtt.config to the config folder in the Homeseer top level directory.
I've restarted Homeseer (several times). The instructions say to go to the Homeseer interfaces page. I can't find a page labeled interfaces but I suspect it might be the the manage plugins page. On that page I can find several plugins to manage, but none associated with MQTT.
Where am I going wrong?
Tom
Tom
Re: HS3 MQTT Plugin
Which version of the plugin did you install? For the raspberry you need the version with 'rpi' in the file name.
Gr. Geert-Jan
Gr. Geert-Jan
