Yes you're correct, sorry for hijackinghvxl wrote:The topic is about otmonitor on a Raspberry Pi. So the information I provided is indeed for a linux system.
Yes I know i can use the -f option on windowshvxl wrote: It is possible to use a configuration file on Windows, rather than the default of storing the settings in the registry. To do that you have to start otmonitor with the -f command line option.
But there is a missing piece when you want to use otmonitor on a raspberry without gui
There is no way to create a config file with the gui-less raspberry (maybe by editing the conf file manually?)
So the other way is to change all the settings on the windows version, but there is no way to export it (or copy the config because its in the registry)
(i know i can setup a linux system with gui, which solve the problem, but I don't want to setup a linux system especially for creating a conf file.
I hope you understand the situation
