Opentherm Gateway
Re: Opentherm Gateway
Postby bruine01 » Sun Dec 13, 2015 11:29 am
Indeed a wrong cable from the webshop. I opened the connector and changed the wires. Thanks again for your help.
bruine01
Postby wjhos » Mon Feb 01, 2016 5:27 pm
Back again,
after some time, i picked up my gateway project. I found out that now some new features have been implemented.
However, i still have some questions :
Does the software recocnize the differences between a DS18B20 and a DS18S20. (at the moment i have a NTC, connected to a pic 16F1825.on the serial port of the 16F88, but not as linear as desired)
What are serial commands for setting my Isense to low/medium/high power demand. I cannot find the info on the otgw pages.
Some comments on the OTmonitor :
I can select a temp. sensor for GPIO A, but that should not work.
For the different LED's i cannot select "none" as output, which i can with the GPIO pins
Furthermore it works splendid.
wjhos
Postby hvxl » Wed Feb 03, 2016 6:11 pm
Yes. The first octet of the device ID indicates the family. The code behaves slightly different when that's 0x10 versus 0x28.
There aren't any. The thermostat decides when it needs more power. That's not something the gateway has to tell it. When the thermostat requests a higher power level, the gateway automatically obliges.
Have you tried? When you select "Temp sensor" for GPIO A, it should immediately change back to "None".
That's correct. What would be the use?
Postby wjhos » Sat Feb 06, 2016 5:33 pm
Yes, you are right about the GPIO pins, i tested with no gateway attached.
Selecting 'none' as output of course has no real meaning, but should be in line with the GPIO , where i can select 'none'.
I am using a Isense; is there a way to switch on the backlight from OTmonitor.
I am planning to mount the GW in the connection box of the Tzerra. Do you know if it is possible to power the unit directly from the boiler ? There must be 24 or so V from the boiler to power the thermostat. It should be available on the HMI bus, but i cannot find any specification.
wjhos
Postby grubciu69 » Wed May 11, 2016 6:58 am
Hi everyone
I am new on this forum. I also built OTG - RS232 version. I have Vitodens 100 (boiler) and iSense AD 289 (thermostat). Most of the options works well, but some do not. What I noticed it yet:
1. In OTG mode the Gateway can not set the clock of the thermostat (automatically or sending a special command)
2. In OTG mode when nothing I set the DHW setpoint controls a thermostat. I can also set a new DHW setpoint in OTG. But what to do to control the thermostat back the DHW setpoint? I cant do this.
For all the advice I will be grateful
grubciu69
Postby hvxl » Fri May 13, 2016 10:40 am
  1. This depends on support by the thermostat. The iSense actually only requests the date and time over OpenTherm when it starts. So normally, after you rip the iSense (without batteries) off the wall and place it back a while later, it will ask you to manually enter the date and time. When you do the same with the OTGW in between and all 3 checkboxes under Clock on the Thermostat configuration screen of OTmonitor enabled, the thermostat will pick up the date and time via OpenTherm.
  2. Use SW=0.
Postby tiga » Fri Feb 24, 2017 11:18 pm
maybe a stupid question....
i was thinking about buying the gateway, but i was wondering....
i will use it with a remaha avanta and an honeywell chronotherm vision.
i want to manipulate it with domoticz.
when i change the room setoint will it appear on the honywell display??
lets say i change the setpoint from 20 to 21 degrees will it say 21 on the honeywell??
thanks
tiga
Postby hvxl » Fri Mar 24, 2017 9:44 pm
I was hoping someone using a chronotherm vision would answer this question, because I don't and so I can't say with 100% certainty. But normally thermostats will indeed update the displayed setpoint when it's changed through the Opentherm interface. In addition, Honeywell thermostats will usually show the Hometronic icon (an "H" with a roof) to indicate that the setpoint was changed remotely.
Postby Rodio » Wed May 03, 2017 8:21 pm
tiga wrote:maybe a stupid question....
thanks
Not the same, but ....
I have a tzerra with a iSense display, and when I change the setpoint in Domoticz the temp on the iSense will follow.
Rodio
Previous
cron
