Output devices from HS2 to HS3
Moderator: b_weijenberg
Postby Wim2008 » Mon Mar 14, 2016 12:21 pm
I work with a output device in HS2 and like to bring this device in HS3. It is an RF device Sun-650 and has a code C6 in HS2.
I configer this device in HS3 with the RFXcom installer also with code C6. The device is in the list of devices in HS3. But I get not reaction of this device in HS3 when I push on ON or OFF.
What must I do more to get control of this device in HS3?
B.R. Wim
Wim2008
Re: Output devices from HS2 to HS3
Postby b_weijenberg » Tue Mar 15, 2016 11:57 am
with device type ARC or AC?
If AC use the correct Unit code.
b_weijenberg
Postby Wim2008 » Tue Mar 15, 2016 12:52 pm
For the Sun-650 I used the ARC.
Wim
Wim2008
Postby b_weijenberg » Tue Mar 15, 2016 1:21 pm
Configure C6 also on the RFXCOM tab of the device.
b_weijenberg
Postby Wim2008 » Tue Mar 15, 2016 2:35 pm
I did. I see also the Sun-650 in HS3 with a on and off button. But the device don't react if I push on ON or OFF.
Wim2008
Postby b_weijenberg » Tue Mar 15, 2016 5:43 pm
please send a screen copy of the HS2 and HS3 device config to support
b_weijenberg
Return to Rfxcom Receivers & Transmitters Forum
