klikaan klikuit AMST-606
Moderator: b_weijenberg
I have an AMST-606 magnet contact from KAKU.
This moduul uses automatic coding.
how can i add this divice
can i do this whit the plugin for homeseer.
on the "RFmonitor" i recieve somthing.
how can i do this
how can i do this
- b_weijenberg
- Forum Moderator
Add the KAKU door sensor in the RFXCOM plug-in on the Input Sensors configuration tab.
I have got a CM15 (http://www.elekhomica.nl/product_info.p ... cts_id=761), is it possible to receive the AMST-606 signals on this interface, without a RFXCOM?
- b_weijenberg
- Forum Moderator
The CM15 can only receive X10.
So if I want to receive KAKU RF signals from that AMST-606 I have to purchase a RFX receiver (http://www.rfxcom.com/receivers.htm) ?
- b_weijenberg
- Forum Moderator
yes, the RFXCOM 433.92MHz receiver is able to receive the KAKU signals.
Then I'm going to purchase an RFXCOM receiver, since the KAKU sensors are cheaper and look nicer.
Thanks for you quick replies, I'm quite new with home automation, but very eager to learn!
- b_weijenberg
- Forum Moderator
To control the KAKU plugin unit you need the RFXCOM transmitter.
Best is to use the new KAKU modules with automatic code system. These units have a dim level that can be set using Home Automation software.
If you order a receiver with an Ethernet interface you must have the model with 2 internal COM ports if you want to use the transmitter too.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by b_weijenberg</i>
<br />To control the KAKU plugin unit you need the RFXCOM transmitter.
So if I want to receive signals from a AMST-606 (or AWST-6000) and at the same time send RF signals to a KAKU device (say AWMR-230) I need a RFXCOM with 2 internal com ports?
Just to be certain...
- b_weijenberg
- Forum Moderator
That's true. For a receiver and a transmitter you need the Ethernet interface with 2 COM ports or 2 USB interfaces.
what devicevalue gives the awst 606 (where can i see this value)
- Willem4ever
- Global Moderator
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Harry</i>
<br />what devicevalue gives the awst 606 (where can i see this value)
249 for open and 9 for closed. (you can check the forum, this has been discussed before)
