Streaming IP Camera on the Pronto incl Pan&Tilt
- Snelvuur
- Forum Moderator
- Contact:
Did you change it as Digit suggested? Also, for my setup i did not change anything at line 890 if i tried http 1.1 it didn't work for me, but http 1.0 did. So try that aswell, i think you only have to change the ones at line 762 if you dont have a ptz camera.
As a side not, can you share your javascript to keep the state on/off, since i have a small issue with one of my devices for that too. Do you save it somewhere global? since you should have that on every page then?
Snelvuur,
Thanks I will try that.
Concerning my script;Sure.It is a little more advanced as I do the same for my amplifier that has no direct input buttons
under home I have a script called HOME (under properties of home)
var power_toggle;
var sound
if (System.getGlobal("power_toggle") == null)
// perform first time initialisation
System.setGlobal("power_toggle", "off");
if (System.getGlobal("sound") == null)
System.setGlobal("sound", "TV"); // Source = TV
Under my Activity (Watch Movies in this case)
// keep state of TV power and act accordingly
if (System.getGlobal("power_toggle") == "off")
System.setGlobal("power_toggle", "on");
CF.widget("TV_POWER", "ACTIVITY_MACROS","MACROS").executeActions();
System.delay(4500);
// CF.widget("WATCH_MOVIES", "ACTIVITY_MACROS","MACROS").executeActions();
//else
//CF.widget("WATCH_MOVIES", "ACTIVITY_MACROS","MACROS").executeActions();
// Set amplifier to right Source
if (System.getGlobal("sound") == "TV")
System.setGlobal("sound", "PC");
CF.widget("SOUND", "ACTIVITY_MACROS","MACROS").executeActions();
System.delay(500);
System.delay(500);
else
CF.widget("MOVIE_TRANSPORT", "ACTIVITY_MACROS","MACROS").executeActions();
and finally a script under the advanced tab of the Device
var power_toggle;
I can always sent you my file if you want.
var power_toggle;
var sound
System.delay(4500);
//else
System.delay(500);
System.delay(500);
else
var power_toggle;
- Snelvuur
- Forum Moderator
- Contact:
Thanks, i think i understand it mostly, so that should be enough. I do have a discrete "on" for my t.v. but no discrete off. I only turn of the t.v. when listening to mp3's but when the t.v. is off and i only want to listen to mp3's it turns the t.v. on.. which is a bad thing
I like the pronto more and more everyday, just received my javascript book from flannagans.. (or whats his name)
I got working !
Very Cool
Very Cool
How can i access the Axis Ip video server from pronto when there is password protection?
Chak, did you try username:password@ipaddress ?
On the pronto that will not work in the current camera script.
- Snelvuur
- Forum Moderator
- Contact:
i did setup a password for the admin part, but you can still see the normal camera's.. dont know what you did.
I have also password on the admin part...I can see the cameras working fine when anonymous is on.
My problem is that i don't want anonymous viewers.
How HTTP authentication is done is all in the RFCs; especially 2616 and 2617 are interesting stuff to read, depending on how sophisticated the authentication scheme used is.
I think you've found a nice challenge for those who know a bit about Prontoscript and a bit about authentication.[:D]
