Notifications bar
Notifications bar
many are annoyed by the continuous display of messages in the Notification bar in version 4.7 and higher that there is no connection with the SC.
This simple modification will delete each message after being read once.
All future messages will be displayed as normal but also deleted after being read.
Make the following change in the file /qmf/qml/qb/notifications/NotificationsBar.qml:
Replace:
				onAction: {
					if (canvas.dimState)
						screenStateController.wakeup();
					if (actionUrl.toString().length)
						notificationBar.hide();
					else if (model.uuid)
						notifications.remove(model.uuid);
					else if (model.type)
						notifications.removeByType(model.type);
with
				onAction: {
					if (model.uuid)
The messages will show up again after a reboot but can be removed again by clicking on it.
This workaround should be acceptable for now.
I expect quby to make improvements to this functionality in future releases.
michel30
Re: Notifications bar
Post by michel30 »
@Toonz
Super, this works thanks for your TIP.
Michel
FunFair
Post by FunFair »
Ì seem to have screwed up something... only getting a white screen without any information.
Ofcourse I forgot to make a backup of the file.... can someone please make a copy for me?
FunFair
Post by FunFair »
Michel was kind enough to supply me with his file. But still I get a white screen. As if I deleted some file by accident or something...
Now I've got a white screen. A hard reset doesn't work, but everything in the background seems to work fine. I can still change things through domoticz.
Also the screen doesn't go into a dimmed state. I hope someone can help me with this. I am going to make a dump of the files.
Looks like your qt-gui doesn't start properly anymore.
Please try to run the qt-gui from within a secure shell with this command:
killall qt-gui; /HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib --daemon 2>&1
... and check the (awful lot of) output for error messages. This should give you some hints as to where things go wrong.
FunFair
Post by FunFair »
file:///HCBv2/qml/Canvas.qml:359:2: Type NotificationBar unavailable
        NotificationBar {
file:///qmf/qml/qb/notifications/NotificationBar.qml:6:1: Expected token `}'
     � � � � id: notificationBar
De hoeveelheid output valt gelukkig mee.
Dit staat er in mijn NotificationBar.qml
import QtQuick 1.1
import QueuedConnection 1.0
import ScreenStateController 1.0
Item {
        anchors {
                left: parent.left
                right: parent.right
                top: parent.top
                topMargin: -height
        height: childrenRect.height
        visible: false
        signal queuedSignal();
        signal itemAdded();
        QtObject {
                property bool expandOnDim: false
                property Timer hideTimer: null
                property Timer blackModeTimer: null
        function show(expanded) {
                cancelHideTimer();
                if (!expanded)
                        collapse();
                if (state === "hidden") {
                        notificationColumn.animateAddItem = false;
                        if (notifications.count === 1)
                                addNextItem();
                        else if (expanded)
                                expand();
                        state = "shown";
        function hide(timeout) {
                if (state === "shown") {
                        if (timeout) {
                                cancelHideTimer();
                                p.hideTimer = util.delayedCall(timeout, hideImpl);
                        } else {
                                hideImpl();
        function hideImpl() {
                notificationBar.state = "hidden";
        function collapse() {
                underlay.clicked.disconnect(collapse);
                underlay.visible = false;
                if (notificationColumn.headerItem !== null) {
                        notificationColumn.animateRemoveItem = true;
                        model.clear();
                        notificationColumn.headerItem.state = "collapsed";
        function expand() {
                if (notifications.count < 2)
                        return;
                if (canvas.dimState) {
                        p.expandOnDim = true;
                underlay.clicked.connect(collapse);
                underlay.visible=  true;
                cancelHideTimer();
                        notificationColumn.headerItem.state = "expanded";
                notificationColumn.animateAddItem = true;
                notificationBar.populate();
        function populate() {
                if (globals.notificationAnimationsEnabled) {
                        itemAddedQueuedConn.signalEmitted.connect(addNextItem);
                        addNextItem();
                } else {
                        while(addNextItem());
        function addNextItem() {
                if (model.count < notifications.count) {
                        model.append(notifications.dataModel[model.count]);
                        return true;
                } else {
                        itemAddedQueuedConn.signalEmitted.disconnect(addNextItem);
                        return false;
        function cancelHideTimer() {
                if (p.hideTimer) {
                        p.hideTimer.destroy();
                        p.hideTimer = null;
        function setBlackMode(enable) {
                if (enable) {
                        screenStateController.screenOffBlackMode = true;
                        scheduleBlackModeTimer(true);
                } else {
                        screenStateController.screenOffBlackMode = false;
                        cancelBlackModeTimer();
        function scheduleBlackModeTimer(show) {
                if (screenStateController.screenState === ScreenStateController.ScreenOff) {
                        screenStateController.screenOffBlackMode = show;
                        var timeout  = (show ? notifications.conf_SHOW_TIME_SCREENOFF : notifications.conf_HIDE_TIME_SCREENOFF) * 1000;
                        p.blackModeTimer = util.delayedCall(timeout, scheduleBlackModeTimer, !show);
                } else {
        function cancelBlackModeTimer() {
                if (p.blackModeTimer) {
                        p.blackModeTimer.destroy();
                        p.blackModeTimer = null;
        state: "hidden"
        states: [
                State {
                        PropertyChanges { target: notificationBar; anchors.topMargin: -notificationBar.height }
                State {
                        PropertyChanges { target: notificationBar; anchors.topMargin: 0 }
        transitions: [
                Transition {
                        SequentialAnimation {
                                PropertyAction { target: notificationBar; property: "visible"; value: true }
                                NumberAnimation { target: notificationBar; easing.type: Easing.OutQuad; properties: "anchors.topMargin"; duration: 300 }
                Transition {
                                NumberAnimation { target: notificationBar; easing.type: Easing.InQuad; properties: "anchors.topMargin"; duration: 300 }
                                PropertyAction { target: notificationBar; property: "visible"; value: false }
                                ScriptAction {
                                        script: {
                                                collapse();
        Connections {
                target: screenStateController
                onScreenStateChanged: {
                        if ((screenStateController.screenState === ScreenStateController.ScreenColorDimmed ||
                                        screenStateController.screenState === ScreenStateController.ScreenOff) &&
                                setBlackMode(true);
                                notificationBar.show();
                        } else if (screenStateController.screenState === ScreenStateController.ScreenActive) {
                                if (!p.expandOnDim)
                                        notificationBar.hide(notifications.conf_HIDE_TIMEOUT);
                                p.expandOnDim = false;
                                setBlackMode(false);
        Connections {
                target: stage
                onOnRootScreenChanged: {
                        if (!stage.onRootScreen)
        Connections {
                target: notifications
                onDataModelChanged: {
                        if (notifications.count === 0) {
                                return;
                        notificationColumn.animateRemoveItem = false;
                        model.clear();
                        if (notificationColumn.headerItem !== null &&
                                         notificationColumn.headerItem.state === "expanded" && notifications.count > 1) {
                                // TODO: add only the new items?
                        } else if (notifications.count === 1) {
                                collapse();
                                notificationBar.addNextItem();
                onNotificationsAddedOrUpdated: {
                        if (p.hideTimer) {
                                cancelHideTimer();
                                p.hideTimer = util.delayedCall(notifications.conf_HIDE_TIMEOUT, hideImpl);
                        setBlackMode(true);
                        if (notificationBar.state === "hidden" && canvas.firstLoadingDone) {
        QueuedConnection {
        Component.onCompleted: {
                itemAdded.connect(queuedSignal);
        ListModel {
        Rectangle {
                width: parent.width
                color: colors.notificationsBackground
                height: notificationColumn.childrenHeight + (notificationColumn.anchors.topMargin * 2)
                clip: true
                MouseArea {
                        anchors.fill: parent
                Behavior on height {
                        enabled: globals.notificationAnimationsEnabled
                        SmoothedAnimation { easing.type: Easing.InQuad; duration: 300 }
                Component {
                        NotificationElement {
                                header: true
                                iconSource: "drawables/notifications-icon.svg"
                                title: qsTr("notification-header-text")
                                        .arg(i18n.capitalizeFirstChar(i18n.greetingText))
                                        .arg(colors.notificationsTextHighlight.toString())
                                        .arg(notifications.dataset.length)
                                activeInDim: true
                                onAction: {
                                        if (state === "collapsed") {
                                                notificationBar.expand();
                                        } else {
                                                notificationBar.collapse();
                                onClose: {
                                Component.onCompleted: notificationColumn.headerItem = headerElement
                                state: "collapsed"
                                states: [
                                        State {
                                                PropertyChanges { target: headerElement; actionButtonIconRotation: 0; actionButtonRotationAnim.direction: RotationAnimation.Counterclockwise; bgColor: "#ffffff" }
                                        State {
                                                PropertyChanges { target: headerElement; actionButtonIconRotation: 180; actionButtonRotationAnim.direction: RotationAnimation.Clockwise; bgColor: colors.notificationsHeader }
                                transitions: [
                                        Transition {
                                                // duration conditional workaround for QtQuick1, on QQ2 it's possible to disable transition
                                                ColorAnimation { target: headerElement; property: "bgColor"; duration: globals.notificationAnimationsEnabled ? 200 : 0 }
                                        Transition {
                                                        PauseAnimation { duration: globals.notificationAnimationsEnabled ? 200 : 0 }
                ListView {
                        anchors {
                                left: parent.left
                                right: parent.right
                                top: parent.top
                                margins: 16
                        height: canvas.height
                        spacing: 4
                        interactive: false
                        property real childrenHeight: (header !== null && headerItem !== null ? headerItem.height : 0) + (count > 0 ? contentHeight : 0)
                        header: notifications.count > 1 ? notificationHeader : null
                        onHeaderChanged: {
                                if (header === null)
                                        headerItem = null;
                        property Item headerItem: null // already exists on QQ2
                        property bool animateAddItem: false
                        property bool animateRemoveItem: false
                        model: model
                        delegate: NotificationElement {
                                iconSource: notifications.getIconUrl(model.type, model.subType)
                                title: model.subType === "_grouped" ? model.text.arg(colors.notificationsTextHighlight.toString()) : model.text
                                actionUrl: notifications.getActionUrl(model.type, model.subType)
                                actionArgs: notifications.formatActionArgs(notifications.getActionArgsFormat(model.type, model.subType), model.args)
                                activeInDim: notifications.count === 1
                                showClose: notifications.count === 1
                                onAction: {
                                onClose: {
                                ListView.onAdd:        {
                                        if (notificationColumn.animateAddItem && globals.notificationAnimationsEnabled)
                                                addAnimation.restart()
                                        else
                                                itemAdded();
                                ListView.onRemove: {
                                        if (notificationColumn.animateRemoveItem && globals.notificationAnimationsEnabled)
                                                removeAnimation.restart()
                                        PropertyAction { target: notificationElement; property: "height"; value: 0 }
                                        NumberAnimation { target: notificationElement; property: "height"; to: notificationElement.itemHeight; easing.type: Easing.InOutQuad; duration: 200 }
                                        ScriptAction { script: itemAdded() }
                                        PropertyAction { target: notificationElement; property: "ListView.delayRemove"; value: true }
                                        NumberAnimation { target: notificationElement; property: "height"; to: 0; easing.type: Easing.InQuad; duration: 200 }
                                        PropertyAction { target: notificationElement; property: "ListView.delayRemove"; value: false }
        Image {
                width: parent.width
                anchors.top: notificationBarBg.bottom
                source: "./drawables/bar-shadow.png"
                fillMode: Image.TileHorizontally
                visible: !canvas.dimState
FunFair
Post by FunFair »
It's working again! It turned out the text editor I used (included in WinSCP) turned all tabs into gibberish. When I opened the file with 'vi' I noticed it.
Copy pasted Michel's file in it trough vi and rebooted without a problem.
Thanks Marcelr and michel30 for the support!!!
I have another idea to suppress the notifications, this one is a bit more intrusive because you will never see any notifications again :-)
In the file NotificationsBar.qml replace all occurrences of ' notificationBar.show()' by 'notificationBar.hide()'
I cannot test this myself as I don't get these notifications anymore.
If someone is willing to try just give your feedback here. Much appreciated.
Thanks in advance.
Slightly different approach:
(excerpt from NotificationBar.qml:)
                cancelHideTimer();
                if (!expanded)
                        collapse();
                                addNextItem();
                        else if (expanded)
                        //MR    expand();
                        state = "shown";
// added MR
                collapse();
                state = "hidden";
// end add
This removes notifications altogether, just need to get rid of the systray icon as well, this is easily handled by setting the number of notifications required for display to an insane amount, in NotificationSystray.qml.
FunFair
Post by FunFair »
marcelr wrote:Slightly different approach:
                cancelHideTimer();
                if (!expanded)
                        collapse();
                                addNextItem();
                        else if (expanded)
                        //MR    expand();
                        state = "shown";
// added MR
                collapse();
                state = "hidden";
// end add
works perfectly!
ams123
Post by ams123 »
Toonz wrote:Hi all,
Thanks in advance.
yes work for me bar is gone
Toon solarpannels
Thanks for the feedback. Nobody needs to worry anymore about notifications :D
Wunser
Post by Wunser »
Different approach is to turn off the notifications alltogether:
in /HCBv2/qml/Canvas.qml
                notifications = notificationsComponent.createObject(canvas);
                // notifications.init();
Comment out the init part
michel30
Post by michel30 »
I updated my Toon yesterday to version 4.9.23 but this notification icon stays on the upper right ( image below ).
This is because it can not connect to the service center error d03 no internet.
Does somebody know how hide this icon?
It is only the icon, there is no notification white balk.
This is not a Notification icon, it is your internetsettings icon.
Two options here:
1. In the topic manuals is described how to get rid of this error caused by the fact that you have no VPN open to Eneco.
2. Another option, more convenient in my humble opinion, is to completely disable this icon. Saves space in your systray for other more useful icons.
To get rid of the icon comment out the following line in /HCBv2/qml/apps/internetSettings/InternetSettingsApp.qml:
registry.registerWidget("systrayIcon", p.internetSystrayUrl, this);
In this case no Wifi icon is shown ever........
Either option will work.....
Return to “Toon Firmware”
