I really need some guidance to do this correctly. Anyone that could help?
Sent from my SM-G930F using Tapatalk
Thanks! Excellent reply!vincenttor wrote:the clambs go on
then it probably measures the difference and wants to know the voltage on each phase so it wants to be connected behind the clamps on every phase and neutral wire to get a reading.
C-
so like the drawing you have to find the phases where the clambs are connected to, A - A B - B C-C
You can do this with a multimeter, or just openup everything and follow the wires.
Do not forget to turnof the power. ( to be fully certain , measure if there is still power on the wires behind the switch . If you measure from phase 1 to phase 2 and 1 to 3 or 2-3 you will get around 400Volts. thats not something you do not want to feel, and 230 not as well)
Btw, on the drawing which i used red circles , its wise to move them up.
Behind the switch
