Toon firmware resource file (as from 4.16.8)
Re: Toon firmware resource file (as from 4.16.8)
Yes that is (probably) in the other resources file containing all images. Will look into this, but low prio
Can also fix this is the next resource file with the other mods, that way we can leave the image files untouched.
how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
- Member
My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Globals.qml is not used anymore for that purpose. If you don't want an app anymore, remove it from the apps folder
No. The app loader follows the link rather than the directory. So the code from the directory where the link points at is used as app, all the rest is ignored.
makkie2002, I see you have a webcam app?makkie2002 wrote:My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Where did your get that from and what's in it?
Because I'm looking for something to show a webcam feed or photo of my frontdoor camera when there is someone pushing my doorbell.
I allready have a script that's sending a picture when the doorbell is pushed but if it also can be showed on my Toon it would be very cool
Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
What do you want to do? It is not possible to edit the .rcc file as it indeed a binary file.
We create our own .rcc files to make it work on a > 4.16.8 toon.
- Member
It is a homemade app ... it is functional but not very performant ... but it does the job to display my IP-cam image (via a weblink to a (m)jpeg) ... please feel free to experiment with it !newwolf wrote:makkie2002, I see you have a webcam app?makkie2002 wrote:My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
- webcam-0.0.7.zip
- (16.39 KiB) Downloaded 599 times
i want to edit it.. to remove the "toon" logo in the left top and add an custom pictureTheHogNL wrote:Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
- Administrator
You can find the guideliness for submitting to the ToonStore here: viewtopic.php?f=100&t=11235#p83091
makkie2002,
Thanks it's working.
- Member
Coolnewwolf wrote:makkie2002,
The new resource file for 4.18.8 has been published (see first post for details)
I attempted to hide the Toon logo in dim state as well but failed miserably for now.
Will look into that further at some point.
Eneco release today 4.19.10. Dont update it, if you like the custom apps.
I think a 4.19.10 release of the resource file is expected in a few days. However, I also advice not to upgrade if you don't have the 'flatline' graph issue.mAiden wrote:Eneco release today 4.19.10. Dont update it, if you like the custom apps.
