Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Postby madpatrick » Sun Oct 07, 2018 8:43 pm
I've update mu icons for the people who are interested
drawables.rar
Drawables
(49.91 KiB) Downloaded 59 times
madpatrick
Postby Toonz » Mon Oct 08, 2018 9:57 pm
waste collection 4.7 is available on ToonStore.
Changelog:
- added a switch to the configuration screen to use your own set of icons for standard waste types.
custom icons need to be placed in the same folder for other extra icons and have the same names as
the standard icons in the wastecollection drawables folder
- user settings were not properly copied to a new wastecollection app version on a Toon 2 (no issues on Toon 1)
With this change you can use your own set of icons which will never be overwritten when upgrading the app.
Postby madpatrick » Sun Oct 21, 2018 12:47 pm
Hi Toonz,
I don't see my custom icons displayed on the Toon.
The icons are copied to the same folders as my custom icons.
Also when you restart the Toon, the switch is not activated any more. It resets itself to off
madpatrick
Postby Toonz » Sun Oct 21, 2018 1:16 pm
madpatrick wrote:Hi Toonz,
Will check in the coming week Will be busy with construction works at home coming days...
Postby Toonz » Mon Nov 05, 2018 11:08 pm
waste collection 4.8 is available on ToonStore.
Changelog:
- config parameters were not saved anymore in version 4.7 (was not tested properly)
- config screen: added a new switch to enable/disable showing waste icons above the thermostat panel
N.B. you do need a new resourcefile version which reads this parameter.
existing versions of the resourcefiles will still show the icon above the thermostat panel
the change for the new resourcefile is ready and will be included in a future resource file by TheHogNL
Postby Toonz » Mon Nov 05, 2018 11:11 pm
can you show the contents of your userSettings.json from the wastecollection folder (you can delete your zipcode/housenr)?
Version 4.8 fixes the issue that the switch is not properly set after a restart.
Postby Cctl01 » Tue Nov 06, 2018 11:38 am
The PMD pickup for postalcode 2216 shows up as - in the overview.
the file in /var/volitile (forgot the file name) shows ? as type.
mijnafvalwijzer gives "Plastic, blik, drinkpakken" as waste type. I'm trying to fix it myself by adding the type. But to help others perhaps it can be added to the toonstore version of the app.
BTW if the project would have been on github or another public place people (myself included) could help in the development.
Cctl01
Postby madpatrick » Tue Nov 06, 2018 7:08 pm
{"Afvalverwerker":"10","Postcode":"1234AB","Huisnummer":"18","Straatnummer":"223","ICSnummer":"0","DisplayIconVanafUur":14,"ExtraDatumsFile":"http://pdebrabander.nl/waste.txt","ExtraDatumsIconsFolder":"http://pdebrabander.nl/icon","CustomIcons":false}
Custom icons are disabled at the moment.
madpatrick
Postby Toonz » Tue Nov 06, 2018 7:17 pm
Hi, can you go into the settings screen of version 4.8, flip one of the switches back and forth and press 'opslaan'? Should be fine from then onwards....
CustomIcons should then show Yes or No instead of false
Postby madpatrick » Tue Nov 06, 2018 7:29 pm
Toonz wrote:Hi, can you go into the settings screen of version 4.8, flip one of the switches back and forth and press 'opslaan'? Should be fine from then onwards....
The custom icon is not visable above the thermostat.
When i choose the app on a tile i see the custom icons, but not on the thermostat.
madpatrick
Postby Toonz » Tue Nov 06, 2018 8:15 pm
The thermostat icons are starting to show up only 5 minutes after a gui restart and thereafter once per day at the configured hour....
When changing settings you might need to wait a day before the thermostat icon shows up (or reboot the gui)
Postby madpatrick » Tue Nov 06, 2018 8:30 pm
Toonz wrote:The thermostat icons are starting to show up only 5 minutes after a gui restart and thereafter once per day at the configured hour....
Restart of the gui did the trick.
Thanks !!
madpatrick
Postby Cctl01 » Thu Nov 08, 2018 7:09 am
Cctl01 wrote:The PMD pickup for postalcode 2216 shows up as - in the overview.
So I can confirm that adding the line
case "plastic, blik, drinkpakken": return 1;
to WastecollectionApp.qml under wasteTypeMijnafvalwijzer fixed the problem.
That brings me to my "new" problem. I wanted to see what the icons look like placed above the thermostat. (looks good) But now they don't go away. I switched the switch off, saved, restarted the GUI, restarted toon and checked the userSettings.json file. ("ThermostaatIcon":"No"}) I now have the icons in two places (tile and thermostat) which is a bit redundant if you ask me, perhaps not if you ask my wife. :roll: :twisted:
Cctl01
Postby Toonz » Thu Nov 08, 2018 10:18 am
You have to wait for the next revision of the resourcefiles.
That will contain an update to the system thermostat app to read the flag "ThermostatIcon" from the wastecollection app settings to hide/show the icon in the thermostat panel.
I will include your app change in the next version.
Moving to github is a good idea but never done that, so need to dig into that a bit first :-)
Postby Toonz » Tue Nov 13, 2018 7:00 am
The latest resource file has now implemented the flag to show or hide the waste collection icon in the thermostat panel.
You can set the flag in the waste collection app settings screen. The change will take effect within a day or when you restart the gui
PreviousNext
Return to Toon Apps
cron
