If you want to debug your script, you can use my Toon btw
No need for this as he already connected his Pi to the Toon. This has all the cables he need to do manual rootmAiden wrote:Manual rooting will work, fortunately you have a U-Boot where the password is known, and in the manual.
Very important to take 3v3, no 5v. Would advise to take a usb to ttl 3.3v..
Connect jumper wires to the ports in the manual on Toon, and the USB to ttl. And then connect with Putty to Toon via serial port
Time for a teamviewer somewhere tonight? Just PM me your 06-number so I can whatsapp you.rotzen wrote:Ah thats a pitty. So for now the only solution is doing a manual root I guess? Or isn't that also not guaranteed to work?
Tried the --boot-only parameter?rotzen wrote:Ah thats a pitty. So for now the only solution is doing a manual root I guess? Or isn't that also not guaranteed to work?
login to toon and enter: passwdrotzen wrote:Thanks guys! Works like a charm now!
PS> Do you know how to change the root password. I will forget the generated password quite soon I'm afraid
I'm not sure if the 'passwd' command is available from 5.0.4 toons. The earlier busybox removed the passwd command.Toonz wrote:login to toon and enter: passwdrotzen wrote:Thanks guys! Works like a charm now!
it does not install busybox. the update-script can do that for you.Kingnl wrote:Hii
Just a couple questions. Does this script got the updated busybox and dropbear
I used this script for my toon and notice that FTP not worked. Pushed busybox Into it and bricked it![]()
And that was with firmware 5.0.4
Okey got a new 1 with firmware 4.22.7
And again used this script and failed to install dropbear
And strange thing about it i use the same script on a r10 and it worked fine
But on a r9 it failes
So Does your script got the updated files thehognl???
What do you mean with r9 and r10? The rooting script is not mine. It is marten jacobs script.Kingnl wrote: And strange thing about it i use the same script on a r10 and it worked fine
sorry i make an mistake i did meen U-Boot version 2010.09-R8 and the r10 ubootTheHogNL wrote:What do you mean with r9 and r10? The rooting script is not mine. It is marten jacobs script.Kingnl wrote: And strange thing about it i use the same script on a r10 and it worked fine
If you PM me, I could teamviewer you into fixing your bricked Toon 1.
Nand backup is useless as on top of the nand a ubifs is created (on a toon1).Kingnl wrote: sorry i make an mistake i did meen U-Boot version 2010.09-R8 and the r10 uboot
it seem that the script need a few times befor it install the necessary files
its rooted now
do some1 know how to make a full nand back??
