Release of 5.2.11 by Eneco/Quby
Re: Release of 5.2.11 by Eneco/Quby
Postby michel30 » Wed Mar 27, 2019 7:39 pm
WickedMaster wrote:
michel30 wrote:Error message:
Upgrading wastecollection on root from 4.19-r0 to 4.20-r0...
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for wastecollection:
* tsc-certificates (>= 1.1.1) *
* opkg_install_cmd: Cannot install package wastecollection.
I upload the 4.19-r0 version and install it manual and that works..
I think something is wrong in the 4.20 version.
I've seen this issue as well. Just install tsc-certificates-1.1.1 from here. After that you'll be able to install the latest wastecollection.
Thanks it works, now everything is up to date :)
michel30
Postby mAiden » Wed Mar 27, 2019 9:05 pm
marcelr wrote:Can you still export your data through Toon's native function? Rumour has it that this functionality has been removed.
There was a bug with it, she seen it after release of this version. Next release it will be fixed. On 5.3.1 it is already fixed. :-)
mAiden
Postby HansS » Fri Apr 05, 2019 6:13 pm
Can anyone point me to what to change for the new firmware to make my own apps work again? I've comments about keyboard, but have no clue what to change?
HansS
Postby TheHogNL » Fri Apr 05, 2019 6:40 pm
Take my app (spot energy) as an example.
EditTextLabel will now popup a virtual keyboard. Can be used if your edit field is at least above the center line of the screen so the virtual keyboard isn't floating on top of it.
The TSC mod also allows the old style keyboard (qnum.keyboard etc). This will, as older version, open a new full screen with an input field and the keyboard.
Postby HansS » Sat Apr 06, 2019 5:10 pm
Oke, thanks. Will havea look at that later. Had a different 'issue', was importing QtQuick 1.x, which is no longer there. Changed it to 2.1, apps working again.
HansS
Postby SDeath » Sat Apr 13, 2019 3:50 pm
Updated to 5.2.11 and everything went fine and seems to be running normal.
Toon1 running firmware 5.2.11 (rooted)
SDeath
Previous
Return to Toon Firmware
